spare tyre
Submitted: Thursday, Jan 05, 2006 at 08:56
David
Spare tyre removal from 4wd. I had a flat a while back and got RACV (Total care) out to change (because of back injury) and I could. Was told by the guy, that due to the spare being over 25kg the would not lift it of or on roof racks or rear tyre mounts. He only did
mine because I have an 80 series with the spare under rear of 4wd. So just make sure if you need there help, that maybe you should ask about this. hope this helps. David
Reply By: Original Banjo (SA) - Thursday, Jan 05, 2006 at 09:30
Indeed David - good point - they are damned heavy - I've got a dicky back and struggle to avoid a "back episode" with all such work - seeing there are so many of this vehicle class on the road, why don't the motoring
services at least have a small lifter of some sort to at least lift it onto a rear mount. Roof racks are special, but rear mounts are standard.
146512
Follow Up By: Kiwi Kia - Thursday, Jan 05, 2006 at 11:36
Perhaps they could agree to do the lifting onto the carrier only if there was someone else available to assist ie. the driver. Not really to hard with two able bodied people working as a team.
400022
