Tuesday, Dec 27, 2005 at 09:15
John,
I would say that the power input cable from the vehicle should still go directly to the trailer battery terminal. You are trying to monitor the amps which the various accessories are using (which has nothing to do with what the car is putting in).
So, on the + battery terminal you should have
(a) the car's input cable and an output (via a self resetting fuse...aka "fusible link" or "circuit breaker") then onto
(b) the + post of the amp meter.....with neg leading onto the accessories (if you have quite a few things to run, it would be adviseable to use a multi-post fuse block here too).
(c) the voltmeter
In practice (in my camper trailer's case), I have not bothered with the amp meter as I don't believe they are really necessary to have. Also, in my particular case, I have a Narva 6 post fuse block and use one of those posts to get power for the voltmeter, rather than hooking it straight up to the + post of the battery. I also have an on-board 240v battery charger, so the + terminal of my batteries (I have 2 x 12 volt in parralel) have the + cable from the charger, the + cable from the truck, and the + cable going directly to the fuse block. From the fuse block, I have cables going to the voltmeter, the fridge, the various 12 volt appliances (CD, water pump, lights etc), and another one to a double 12 volt socket in the battery compartment. That way everything is "fused".
Hope this helps; not confuses you even more...hehehe
Roachie
399186
