Monday, Dec 19, 2005 at 15:22
Actually, on re-reading your post, I'm a bit confused why you'd be earthing to a dash board bolt anyway (or is your relay inside the vehicle?).
The wiring I would have thought, would have seen the following apply:
Relay has 4 posts:
1 goes to the light/s
2 goes to the Battery + terminal
3 goes to the Battery neg terminal (or another very good earth point)
4 goes to switch on dash board.........other side of switch goes to the high beam wire (I usually splice it in just behind the headlight plug itself). This wire does not need to be of a very high gauge (speaker wire would do).
The POS & NEG must be of very good quality and heavy gauge, as must the one that goes to the light/s. It's best to run 2 separate wires, one to each spottie.
Sorry if it sounds like I'm talking chit (most blokes on here are used to me doing that by now anyway).
Roachie
398057
