Layout of gauges on my GU
Submitted: Sunday, Dec 18, 2005 at 10:35
Member - Roachie (SA)
A few people have asked to see how I've set up my gauges in the GU. Now that I'm a bloody expert in photobucketofchit (hahahaha), I'll give it a go:
Fingers crossed:
Reply By: Michael ( Moss Vale NSW) - Sunday, Dec 18, 2005 at 10:43
Roachie, Are u sure thats a GU??? :)-+-<
| Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.Member My Profile My Blog Send Message |
144365
Follow Up By: Member - Roachie (SA) - Sunday, Dec 18, 2005 at 11:11
Yeh, I'm nearly sure that somewhere underneath all that krap, there lives a normal GU....hahahaha
397863
Reply By: gramps - Sunday, Dec 18, 2005 at 10:46
You've got it down pat now Roachie :))
It looks more bloody complicated than that aircraft cockpit photo that was on here a while ago LOL
144366
Follow Up By: Member - Roachie (SA) - Sunday, Dec 18, 2005 at 11:12
Just don't ever look at the wiring and ask me "what does THAT wire do?"
397864
Reply By: Member - Trevor R (QLD) - Sunday, Dec 18, 2005 at 10:59
G'day mate,
I would say you win.
I thought my dashpod was cluttered........ until I saw these photo's.
As I said once before you want to apply for NASA's R & D team for the next design of the space shuttle, your experience with gauges probably is more extensive than those that allready work there.
I would be too short to see over the top of that cluster of VDO gauges, but I do want them just the same hahaha.
Cheers Trevor.
144371
Follow Up By: Member - Roachie (SA) - Sunday, Dec 18, 2005 at 11:10
G'day mate,
Yeh they do take up a bit of space and I find that if I'm driving through any gnarly country in 1st Low, I have to sit up a bit so I can get the best possible view of the track.
The photos are Pulitzer Award quality, but you might be able to pick out the EGT digital readout on the steering column. It has a small yellow toggle switch on top which enables me to flick between upper and lower thermocouples on the turbo.
The same idea exists on the Voltmeter (partially hidden behind the GPS) which has a toggle switch for checking either of the 2 batteries.
The 4 VDOs on the dash are (from L to R); oil pressure, oil temp, water temp, boost pressure. The air gauge lives on the A pillar and the LowWater Engine Saver alarm's huge LED is mounted on top of the A pillar. The alarm module itself is attached by 2 cable ties to the T piece just below the air gauge.
Roachie
397862
Follow Up By: Member - Trevor R (QLD) - Sunday, Dec 18, 2005 at 11:38
Roachie If you don't mind me asking, what was involved with the setting up of the EGT and what did it cost and was it a bugger to install yourself or did you get someone to do it??
I understand that it came from Ian at Thermogaurd, correct me if I am wrong, so I could easily find his details as I have been thinking about putting this gauge on as a priority.
Thanks Trevor.
397870
Follow Up By: Member - Roachie (SA) - Sunday, Dec 18, 2005 at 11:54
Trevor,
I did it all by my self!!!! Except that when I first installed it I didn't have a bung in the exhaust dump pipe into which I could screw the thermocouple, so I decided (on Ian's advice) that seeing as how I'd have to get a suitable thread put somewhere, it may as
well be in the manifold. I did not feel confident about doing that part myself, so I got a local mechanic to unbolt the turbo and tap the hole in the manifold (it had to be unbolted so that any swarf could be prevented from dropping into the turbo).
However, your new 3" exhaust system should have a readily accessible bung that can be removed and the thermocouple simply screwed into it.
The wiring is school-boy stuff.
Roachie
397874
Reply By: Rock Crawler - Sunday, Dec 18, 2005 at 11:34
Put put up a good fight , and your sort of close lol .
144372
Reply By: Member - JohnR (Vic)&Moses - Sunday, Dec 18, 2005 at 11:37
http://photobucket.com/tags/?error=404 I am not sure what you have given me mate but that is what I get from your post and no pictures.......
144373
Follow Up By: Member - Roachie (SA) - Sunday, Dec 18, 2005 at 11:55
That's bloody strange!!! the piccy's are definitely there and others are seeing them....Can't work that one out
John, sorry
Roachie
397876
Reply By: Member - Kingsley N (SA) - Sunday, Dec 18, 2005 at 11:41
All I can see is four blue squares with a red cross in the top LH corner!
Right click gives me a few options but still no piccies.
What's the go Roachie?
Kings
144374
Reply By: Mad Dog (Australia) - Sunday, Dec 18, 2005 at 11:46
404 error, what happened to the pics, did you delete them from photobucket
144375
Follow Up By: Member - Roachie (SA) - Sunday, Dec 18, 2005 at 11:58
That must be why....yes, I did delete them from photobucket.....wrong thing to do by the sounds of it, eh?
397877
Follow Up By: Mad Dog (Australia) - Sunday, Dec 18, 2005 at 12:28
yeah Bill, leave them on photobucket for as long as possible.
397881
Follow Up By: Truckster (Vic) - Sunday, Dec 18, 2005 at 21:31
Yea makes it a wee bit harder to see, if you delete them.
397944
Reply By: glenno(qld) - Sunday, Dec 18, 2005 at 11:51
Does you have a engine block temp monitor Roachie .
Rotronics etc .
link text
144376
Follow Up By: Member - Roachie (SA) - Sunday, Dec 18, 2005 at 11:59
No.....do you think I need one? hahaha
397878
Follow Up By: glenno(qld) - Sunday, Dec 18, 2005 at 12:07
Wouldnt hurt . LOL
397879
Follow Up By: Member - JohnR (Vic)&Moses - Monday, Dec 19, 2005 at 12:03
I agree Glenno, he needs another thing to worry about rather than worry his bank clients.
398031
Reply By: Member - Brian (WA) - Sunday, Dec 18, 2005 at 12:17
Hi Roachie. Was you aiming the camera in the right direction. All I can see
is blue sky cheers brian
144377
Follow Up By: Member - Roachie (SA) - Sunday, Dec 18, 2005 at 12:26
Yeh sorry mate....I didn't know you're not allowed to delete them off photobucket once they're loaded onto EO. So, I deleted them and also off my camera etc, so I've had to go and do it all again. See my other post "Take 2"
397880
Follow Up By: gramps - Sunday, Dec 18, 2005 at 12:38
Hmmmm. I'm still getting them here but maybe that's just a cache thing.
397885
Reply By: Motherhen - Sunday, Dec 18, 2005 at 16:44
Who was it that recently posted about fitting the pillar pod with three guages? I can't find the thread now. I wouldn't be able to see over the dash either with one like Roachie's - then again, i suppose i would be so busy monitoring all the guages that i wouldn't have time to look at the road anyway lol.
144403
Follow Up By: Chaz - Sunday, Dec 18, 2005 at 20:31
Motherhen,
HERE is the finished product. All the gauges are hooked up and working well. So far maximum boost is 18psi and pyro temp is 450deg C. I put the probe about 50mm past the exhaust turbine wheel.
397931
Follow Up By: Motherhen - Sunday, Dec 18, 2005 at 20:43
Thanks Chaz - and glad the readings are going well.
397933
