Saturday, Dec 17, 2005 at 17:52
Here is a cut and paste from a recent post about the same matter...... see the rest of the post: Number 28,798..............
Okay; where do I start??? hahaha
The first thing I'd like to say is that
mine (and yours by the sound of it), has never actually over-heated (ie: never got to the point where it has boiled and caused me to stop and fix something).
However, it has got right up to almost being in the RED zone at times. The things I've already done (and which were probably a waste of time/money in retrospect) are:
1. New PWR double-sized radiator with free-flowing tubes (so they say)
2. New fan hub
3. New thermostat
4. Cut hole in bonnet and put scoop above turbo
5. Fitted new turbo recently (I thought this MAY have reduced heat a bit as the OE turbo is water-cooled and the new Schwitzer is not), but that wasn't the primary reason for upgrading.
6. Tried removing Lightforce 240s and putting them on top of the bullbar
7. Tried driving with the plastic air-
dam underneath the radiator removed
8. Tried various types of anti-freeze/boil stuff
9. Stuck 2 bottles of chit in the radiator that are supposed to seal up any tiny cracks in the head if there are any (can't remember the name of it, but I got it from Repco and it was recommended by somebody on here).
10. Have fitted a VDO water temp gauge with sender unit mounted in top radiator hose
11. Have fitted a EGT gauge to see if there is any relationship between exhaust temps and water temps (there really is no relationship apart from if the engine is running for prolonged periods at high speed....anything over about 105k/h, both temps do go up).
12. New radiator cap
13. New radiator hoses
14. Added a 10" Davies Craig fan in front of air-cond condenser which I can manually turn on....maybe I should upgarde this to a 12" or 14" jobbie?
The only thing that I haven't done yet, and which someone on here suggested I should do (can't remember who it was, but he was a bit smug about how he did things;-)) is to change the impeller in the water pump. The bloke who talked about it said he could fix my problems really easy by fitting a new impeller which would stop cavitation of the water. He would not elaborate, even though a few of us asked him for more info :-((.
I've also thought that maybe I might take the winch off this summer as
well as the
driving lights and see if the extra air flow assists.
We have had a few quite warm days lately, but I haven't had to go too far and not with the camper on anyway.
One thing to keep in mind is that when the Nissan's gauge goes up to around the 3/4 mark, your truck is not over-heating at that point. According to my VDO gauge, the temp in the top hose at that time is around 110oC and it seems as though the concensous of opinion is that up to about 120oC is okay when say, going up a
hill....but you wouldn't want to see it up at 120oC all day. I haven't yet gotten the VDO gauge to go to 120oC and so I try not to worry too much. I rely more on the VDO gauge these days (even though the Nissan gauge is still functional). I also tend to drive and change gears according to the EGT gauge as much as anything else.
It has been said on this
forum before that the 4.2 motor does not have anywhere near the size water galleries that the Toyota 4.2 motor has. As such, you have this huge mass of motor that has smallish "veins" running through it trying to collect the heat and take it through to the radiator for cooling purposes.
Another thought which I've had recently is to instal another temp sender unit in the intake where the water from the bottom radiator hose is about to re-enter the motor. Having changed turbos, I now have a "blank" bolt where the banjo bolt used to be that had water going to or from the old turbo. I could take this plug out and have it drilled and tapped to take a VDO sender, which I could then take to my gauge via a switch. That way I could switch between top and bottom radiator hoses and see how much cooling the radiator is actually achieving. This is the same thing I have done with my EGT gauge; have a thermocouple above and below the turbo so I can swap between pre-turbo and post-turbo EGTs.
I don't suppose this helps you, other than to say that you don't really have to worry too much as long as your Nissan gauge isn't going too far past 3/4 of the way.
Roachie
144310
Follow Up By: Member - Roachie (SA) - Saturday, Dec 17, 2005 at 17:55
2 other things I've thought of doing, but haven't yet done so.....
a). add a new Davies Craig electric water pump (EWP) into the bottom radiator hose....probably would need to do away with the original water pump impeller if I did this.
b). Do away with the standard cooling fan and add 2 big mutha electric fans......
I too timid to try either of these options unless somebody else says they've done it and it works.
397776
Follow Up By: Member - John - Saturday, Dec 17, 2005 at 18:42
Roachie, I tried the EWP and Electric controller on a 2.8 TD Nissan, it couldn't put enough water thru to cool it on normal running. Waste of money in that application.
397787
Follow Up By: Sir Diamond - Saturday, Dec 17, 2005 at 18:53
roachie have you tried removing the head and opening up the bleep y little holes they have in the head gasket to stop restriction in the water flow to the head yet?
397788
Follow Up By: Exploder - Saturday, Dec 17, 2005 at 19:00
Did you fit the right one, the 4WD and Pro-Formance car ones pump at a rate of 110L/per minute at full voltage, I would of thought that would have been more than enough water flow.
Sir Diamond> That is a very good idea;It would have an effect if indeed there were a restriction on the gasket between
the block and head
397789
Follow Up By: Member - Roachie (SA) - Saturday, Dec 17, 2005 at 21:53
G'day Diamond,
Never had the head off the Patrol.....shouldn't have to do that until about 500,000klm.
I think I'll just try to accept that the Patrol is a truck that will go all day , but not at high speeds........ I think I can live with that.
Cheers mate
Roachie
397830
Follow Up By: Member - JohnR (Vic)&Moses - Sunday, Dec 18, 2005 at 09:55
Roachie, I look through your list of camping luxuries and you seem to have to take heaps, so much so the drag on your engine must be heaps at the higher speeds. I guess that you have the hotter (in performance terms) engine is to make sure it can cope with that side of the problem. Gearing of the engine to the road is changed and improves the overheating problem in 4th gear rather than 5th as stated below I see.
How many of these overhating vehicles are fitted with oil coolers, bearing in mind that performance vehicles usually require them to be fitted for longevity? I don't see it mentioned in your rig description Roachie. I would have thought the oil pathways would be another coolant avenue.
Roachie andother drag factor you add is the demand to carry so much and you have a roof rack on top to ensure that you achieve that. I know you have to ensure the family go along but can your look to travelling a little lighter somehow? I know that the total mass drag is heaps more than
mine and you like to take a generator and all that stuff. I have hung a bit on you before on that. I had to reduce the weight I take for preservation of axles and drive. Not gone to a 6 wheeler yet to cope.
I know some bank managers with my bank, don't necessarily think more is better.
Sir Diamond, I have a good
pic of you bestowing a hand on Lady Diamonds' posterior while she has her head in the Jack. Hope you have great Christmas mate. You too of course Roachie - Christmas I mean, not the hand on Lady Diamonds' posterior. ;-)
397856
Follow Up By: brd - Monday, Dec 19, 2005 at 11:21
Hi Roachie
I was just wondering whether the move to a 5W30 oil (presumably from the recommended 15W40) may be counter productive in relation to overheating issues. Viscosity choice is probably the most important aspect of oil selection, and (I think from memory??) a minimum 12.5 cSt viscosity is required for good hydrodymanic lubrication, at what ever temperature the oil is. According to my old viscosity charts, at 80C, a 5W30 would be roughly the minimum, while a 15W40 would be about 16.5 cSt ( a healthy margin).
The 80C measured oil temperature is from the oil
pool, and does not reflect the temperature at the many loaded parts of the engine, where the actual temperature affected viscosity is most important. Temperatures around bearings and piston rings will be much higher than 80C.
I'd be interested to know how you go with it. Amsoil is a good oil, and its additive package may over ride the viscosity aspect to some degree, but if you see the oil temp increase, it will be due to oil film rupturing...and accelerated wear.
All the best.
398023
Follow Up By: Member - Roachie (SA) - Monday, Dec 19, 2005 at 12:08
Thanks for the info there brd. I am a little sceptical about using the 5w30 oil, but the AMSOIL agent says that he runs in his GQ ute. However, I am mindful that his GQ ute is a
farm-type truck with no turbo and unlikely to be called upon to drive hour upon hour on highways at 100k/h with a gross mass of about 4.5T. I certainly will be keeping a close eye on the oil temp and pressure gauges once I do change over. I will also be having the 1st sample analysed@ around 4,000klm.
Cheers mate
Roachie
398033
Follow Up By: Russell from Synforce Lubricants - Wednesday, Dec 21, 2005 at 16:22
g'day roachie, long time no seee eh
as one of the tasks of an oil is to take away heat, any radical change in viscosity can effect the heat trabsfer away from components.
heat transfer (rate) is effected by flow, in other words to get the most you
cave to avhieve the right flow. if the oils is passing over the components too fast (thin oil) then the oil will not have had the opportunity ot have absorbed the heat from the component.
thick oil will stay too long and even cause the component to heat up by not taking the heat away quick enough.
when playing with different viscosities be careful that you are not going too far either way and causing either of the above too happen.
there are other factors within the design of an oil that will also tend to cause over heating, one being the shear strength of the oil itself, that is the ability for the oils film not to brake down or "shear" leaving little or bad lubrication that will obviously cause an increase in friction hence heat. "shear stability index"
the ability of the oil to resist viscosity change is another factor that can cause heat, as if the oils viscosity is in a loss situation then the heat transfer rate is also effected as the oil will have thinned out at temperature. "viscosity index"
not suggesting that any of this is your problem, but to be aware of some of the things that may
well contribute to it. j
merry christmas to you all.
398422
Follow Up By: Member - Roachie (SA) - Wednesday, Dec 21, 2005 at 19:20
G'day Russell,
Yeh, long time no hear!!! I've been hangin' around here, but where have you been? I haven't seen you on this site for donkey's ages.
Thanks for that info.....it certainly is a juggling act to get all the different aspects "just right".
All the very best to you and yours for the new year and a happy christmas too.
Roachie
398445
