Here goes dose the picture turn up fingers crossed
Submitted: Saturday, Dec 17, 2005 at 09:28
Eric from Cape York Connections
Reply By: Eric from Cape York Connections - Saturday, Dec 17, 2005 at 09:30
No but I think I am getting there.
All the best
Eric
144247
Follow Up By: Eric from Cape York Connections - Saturday, Dec 17, 2005 at 09:35
397686
Follow Up By: Member - Paul P (Bris) - Saturday, Dec 17, 2005 at 11:05
G'day
See you second post. As you can see your path works if it is posted usung the format from the bottom of the page
(img src="
http://domain.com/image_path" ) substitute your image path info for the bit in " " . (Replace brackets with < . See bottom. I used those to achieve the post).
Paul
397712
Reply By: Eric from Cape York Connections - Saturday, Dec 17, 2005 at 09:35
I did It but have no idea how.
144249
Reply By: Eric from Cape York Connections - Saturday, Dec 17, 2005 at 09:38
144250
Follow Up By: Big Kidz (Andrew & Jen) - Saturday, Dec 17, 2005 at 09:41
what about this
pic??
397690
Follow Up By: Eric from Cape York Connections - Saturday, Dec 17, 2005 at 09:48
How you do dat
397691
Follow Up By: Truckster (Vic) - Saturday, Dec 17, 2005 at 19:18
ERIC.... NOT the one in square brackets --->> try the one that has <img src="
397800
Follow Up By: Truckster (Vic) - Saturday, Dec 17, 2005 at 19:19
397801
Follow Up By: Truckster (Vic) - Saturday, Dec 17, 2005 at 19:20
397802
Follow Up By: Truckster (Vic) - Saturday, Dec 17, 2005 at 19:21
397803
397804
Follow Up By: Member - Duncs - Saturday, Dec 17, 2005 at 22:45
Gee that photo, 8 of 9, is familiar.
I've got one just like it. I'll bet others have too.
Only the faces have been changed to protect the innocent.
397837
Follow Up By: Eric from Cape York Connections - Sunday, Dec 18, 2005 at 05:06
Thanks truckster and all I think I can do it easally now.
Gramps gave me a call and talked me through it
Once again thanks
All the best
Eric
397849
Reply By: Eric from Cape York Connections - Saturday, Dec 17, 2005 at 09:50
Na got no idea.
All the best
Eric
144251
Follow Up By: Member - Roachie (SA) - Saturday, Dec 17, 2005 at 09:54
Me neither mate............but at least you're brave enuff to have a go. I wouldn't know where to begin. hahahahaa
397695
Follow Up By: Eric from Cape York Connections - Saturday, Dec 17, 2005 at 09:56
At least you can get a picture at the bottom of your post.
All the best
Eric
397696
Reply By: Sky Pilot - Saturday, Dec 17, 2005 at 10:14
How about this one?
144253
Follow Up By: Sky Pilot - Saturday, Dec 17, 2005 at 10:17
Now, how do I show you how I did that, without the text converting into a picture? I'll try by using the wrong brackets. The correct brackets to use are theones I'll replace them with [] ones so you can see the text.
[center][img border=0 src="
http://www.kimberleykampers.com/images/Bedouin%20Beach.jpg" height=268 width= 400>[/a][/center]
Hope that worked.
397699
Follow Up By: Sky Pilot - Saturday, Dec 17, 2005 at 10:21
Arrggghh it didn't display the correct brackets then. The proper brackets to use are the greater than and less than symbols on the comma and fullstop keys.
Also, you can get the exact location of the picture by right clicking it and using the copy image location choice on the right click menu.
397701
Follow Up By: Eric from Cape York Connections - Saturday, Dec 17, 2005 at 10:42
397705
