Thursday, Dec 15, 2005 at 11:53
Brian,
I'll say up front I sell these
winches, so take what I say with a grain of salt....
I have seen how the cables are rolled onto the drum - the bolt is put into the little eye-let, the drum is rotated, and the cable is wound on. It is not wound on tightly in the factory, hence the reason pretensioning is required.
You will probably find the cable had a bit of spring in it, and actually snapped the head off the bolt as it sprung back. These bolts are not real strong, as you are normally required to have a few layers of cable on the drum before operation. The drum itself takes the force, not the bolt. It is kinda like if you wrapped a rope around a tree a few times, then pulled on the rope. The other, disconnected end has absolutely no force on it.
JD, I'll be very interested to see how you go with yours. It is one thing for the importer to try them out and tell you how good they are, but quite another for someone that has paid their hard earned for one.
Chump
397460
