Wednesday, Dec 14, 2005 at 19:10
Jeff,
Yeh mate, still got the leak. A bloke I spoke to the other day (can't remember where....forgot), said that those festo press-on fittings MUST have the hose exactly square at the end in order to avoid leaks. I've got at least 4 "T" juctions (ie: 12 points) that could be possible leak points. There is a 3 way (Mercedes emblem style) brass
junction near the compressor, which takes the air from the compressor to the 2 tanks, as
well as a brass "T" piece before that (between the compressor and the Merc emblem) which has the ARB pressure switch off to the side.
I have removed the padded handle altogther and have a one-way valve bolted into the compressor's outlet.
Coyote.....
The outlet on the bullbar is for inflating the front tyres and I also use it when I'm doing any oil changes....... I have an
old truck air tank on a tripod which I place the 10.5litres of engine oil into...it has fittings for pumping up pressure, a hose coming out the bottom and a simple tap near the end of the hose. So when the truck is up on the ramps and I'm perched up on a ladder leaning over the bonnet trying to get the oil in there, I don't have to worry about juggling a funnel and a 5 litre oil container. Instead, I climb the ladder, place the hose in the rocker cover, turn to tap on, (having already turned on the air tap on the bullbar to start building up a bit of pressure). Then it's just a matter of watching the oil quietly move into the motor until I see/hear the gurgling which signals that the oil is depleted. Shut off the air pressure and the oil flow and turn on the relief tap near the top of the tank.
Then there's the air horns....very loud, but i can isolate them and just have the little Thomas The Tank Engine type "peep-peep" horn if the coppers ever do a road-worthy
check on me.
The outlet at the back is actually inside the back door and I can use the air hose to reach the back tyres as
well as the camper trailer tyres. I have 2 separate air hoses....the one I keep in the back which i use for the tyre inflation, oil decanting etc and the yellow plastic coiled hose which lives under my
seat and, as I said before, is only used for dusting down the cab area etc using the 3rd RYCO outlet above driver's head.
Hope this explains it a bit better.
Roachie
397352
