AGM Batteries
Submitted: Tuesday, Dec 13, 2005 at 22:43
Lorne
I want to install a AGM as my aux. battery and was wondering on peoples
views on this and what experience you have had with them. Can a 4.2L Diesel be started off one of these if the need arises? My other battery is a Century MP600 (N70Z type). The AGM I'm looking at is a Remco 100AH for $275.
Lorne
Reply By: Member - Roachie (SA) - Wednesday, Dec 14, 2005 at 08:10
I gather these don't take too kindly to the heat experienced under the bonnet and you should mount them elsewhere if you want to get the kind of life-expectancy they are reknowned for. As for their ability to start a diesel, I'm not sure; sorry I can't be more help.
Roachie
143780
Reply By: Mike DiD - Wednesday, Dec 14, 2005 at 08:23
According to Remco, their AGM's life will be reduced to 1/5th if you keep it at 50 deg (typical engine compartment temp) compared with 20 degrees. Of course the battery will only be at this temperature while you are are driving, so the average temperature will be less.
The 5-second discharge rating of the 80AHr Remco is 550 amps.
Mike
143782
Follow Up By: signman - Wednesday, Dec 14, 2005 at 09:32
Where can you mount a battery in a vehicle where the ambient temp is 20 degrees???
397264
Follow Up By: Mike DiD - Wednesday, Dec 14, 2005 at 10:43
If you're in Queensland - nowhere :-(
397271
Follow Up By: Member - Roachie (SA) - Wednesday, Dec 14, 2005 at 11:24
What about in the fridge? ;-))
397283
Reply By: Notso - Wednesday, Dec 14, 2005 at 09:30
There is an interesting discussion on AGMs here
http://www.fridge-and-solar.net/agm.htm
143790
Follow Up By: Mike DiD - Wednesday, Dec 14, 2005 at 10:52
I agree that AGM batteries have many advantages - that's why I bought one.
Unfortunately one of the arguments he uses to convince people to buy AGM's off him is the oft-repeated but never substantiated myth that a car battery is NEVER charged above 70%. Thirty years (generators and relay regulators)- yeah, today - rarely.
www.pajeroclub.com.au/forum/forum_posts.asp?TID=8397&PN=1
397273
Follow Up By: Notso - Wednesday, Dec 14, 2005 at 11:17
I don't have one of them.
On the advice of an auto electrician I have two Century Severe use N70ZZ batteries under the bonnet with a smart relay. First two batteries both standard Nissan original equipment n70zzs lasted 5 years. Running Freezer 24 X 7. No special treatment sit on a trickle charger when not in use.
The lec lec reckons you get a better warranty, faster charging, better heat resistance.
I have got a deep Cycle in the camper trailer though. It's about 3 years old and starting to lose capacity. Might get a megapulse and se what happens.
397281
Reply By: Member - Raymond - Wednesday, Dec 14, 2005 at 11:26
Lorne
I had one of the AGM's in the GU. No problem starting the Diesel and very quick to recharge. Val from fridge and solar recommended that I put a heat shield around the battery like the original one on the starting battery with the air duct to increase the life of the battery.
Heat under the bonnet is a real problem in modern cars and really does kill batteries, the Mondeo would kill one every 18 months without fail
Ray
143809
Reply By: willow 2839 - Wednesday, Dec 14, 2005 at 12:55
Lorne,
I have a 98 Prado. The Prado's have little room under the bonnet for a second battery, let alone one of decent size, so i ran it into the rear cargo area. For this reason i used a 'Full River' 100a/h AGM. Cost me $210. I built a battery box from ply and installed into the box, a fridge plug and 2 x cigarette lighter outlets for the lights (Cost $50). Battery connects to an Anderson plug on side of box and leads from Redarc solonoid run from under bonnet to other Anderson Plug, which connects them together. Hey prestow, you now have a removeable power source. It sits nicely behind the fridge in an area where little is stored anyway so it doesn't get in the way. Cabin temp is not a problem.
This set up is not for every one, but i find it works very
well with greater versatility.
Willow
143817
Reply By: Alloy c/t - Wednesday, Dec 14, 2005 at 15:12
A. have a good look in the archives. B. I use an 80amp hr Fullriver AGM HGL as my start batt and a 90amp Fullriver AGM HGL as my aux batt both underbonnet in standard tojo batt carriers in my 80series turbo diesel , live in QLD , hot ?? yes !!! Never a problem starting or recharging ,also run 3x 80amp Fullriver AGM HGL in/on camper trailer recharged via anderson plug and /or solar whilst camped ,, most people seem to have the FALSE impression that AGMs cannot handle heat ,, cows excrement !!! AGMs are used in some of the hottest and coldest
places on Earth and off it !! ie: the space station /shuttles ect so a 4x4 enviroment is childs play.
143847
