IFS Hilux suspension
Submitted: Tuesday, Dec 13, 2005 at 18:39
Twinkles
Been trying to make up my mind about new
suspension for my IFS Hilux. Got prices and details from ARB, TJM, Ironman, Rancho, Procomp, and a place in Frankston (Vic) for Ride Pro. The Ride Pro quote seems good. Springs have military wrap, greasable shackles, U bolts, bushes, torsion bars, steering damper and Ride Pro gas shocks.
Anyone got comments, experience, advice?
Also want a long range tank.
Reply By: ACDC - Tuesday, Dec 13, 2005 at 19:51
I'd put ride pro in the same class as ironman and pedders.
stick with ARB TJM or EFS.
143719
Follow Up By: Member - Crazie (VIC) - Tuesday, Dec 13, 2005 at 20:19
why stick with ARB, TJM and EFS? cause they make all their own gear stuff....?? Most of their gear is prob sourced from the other 3 you mentioned...
397204
Follow Up By: ACDC - Tuesday, Dec 13, 2005 at 20:36
At least if you stick with the top brands you get a reasonable product for your money the other three are garbage!!!
397212
Follow Up By: Peter McGuckian (Member) - Tuesday, Dec 13, 2005 at 20:56
ACDC
Have to disagree! Ridepro are imported b ATECO and are a big US brand. Their gear may be made elsewhere but is pretty good. Had
mine for 12 months on the GU and it is great. I think you'll also hear a few very good things about Ironman now.
397215
Follow Up By: ACDC - Tuesday, Dec 13, 2005 at 21:04
We have a gu in work at the moment with ride pro
suspension the shocker bushes are all stuffed and the back springs have sagged the front is 20mm higher than the rear.
397218
Reply By: Sarg - Tuesday, Dec 13, 2005 at 20:40
Have a look at Post 28828
www.automotive-online.com/
suspension-steering/shock-absorbers.html - 116k -
143731
Reply By: Turbo Diesel - Wednesday, Dec 14, 2005 at 09:33
Twinkles I'm looking at doing the same thing to my lux as soon as i can afford it, let us all know what you decide to do in the end. I'm lost with
suspension at the moment, I had Old man emu on the 80 series and it was great, however prices seem to have gorne up over the last 4-5 years.
143793
Reply By: friar - Wednesday, Dec 14, 2005 at 14:02
Hi Twinkles
My local spring works supplied my rear springs with 50mill lift ,wound front ifs up 30mm & fitted efs shockys,2 trips to cape
yorke,could not be happier with the set up,rides good empty or loaded although empty is long range tank ,2aux batteries
water tank,recovery gear,& camping gear that never sees the shed,hope this helps.
My 4x4 is hilux extra cab 1999,with alum canopy.
Friar
143828
Follow Up By: Twinkles - Wednesday, Dec 14, 2005 at 14:12
Hi Friar,
Did you put greasable shackles, polyurethane bushes and new U bolts as
well? Did you do the work yourself?
397321
Reply By: friar - Wednesday, Dec 14, 2005 at 16:38
Twinkles
The spring works fitted
the springs,rubber bushes,non greasible,I bought the shockys,seperate, & fitted them myself.From memory
the springs were about $350 fitted & shockys around $600.Wound the front up myself,a bit of trial & error.
Friar
44
143858
