polyair airbags
Submitted: Sunday, Aug 07, 2005 at 19:41
ThreadID: 25424 Views:7259 Replies:6 FollowUps:11
I have read reports on the use of these air bags,my Usage results have been negative,both bags developed leaks,one almost immediately, the other 3 years down the track.
The leakage area was around the brass nipple in the top of the bag,in both instances,the company refused to replace the first unit, but gave a consessional reduction to replace one, the other is now being submitted for evaluation.
The combined cost could have bought me a new set of Firestones,far better quality! in short not impressed.
The service once claim resolved, was superb,ordered 3pm delivered SE Qld country by 8am next day
Reply By: Member - Phil G (SA) - Sunday, Aug 07, 2005 at 19:58
A lot of the problem with polyairs is the installation.
Some people don't appreciate that the bag gets pulled a fair way down the coil when the vehicle articulates. So you must have enough spare tubing lying free at the top.
Otherwise its very easy for the top connection to get pulled off.
I've fitted a few sets of these, and the only problem I've had was when I cut the tubing too short. Gladly, only done that once.
AnswerID: 124211
Follow Up By: the guardian - Sunday, Aug 07, 2005 at 20:44
Can appreciate your comments re installation,had mine and 80 series fitted by agents in Rockhamoton,80 series was ok ,had plenty of articulation room on hoses,mine has not gone off bitumen yet,have a mate who has 11 years of use still ok ,my reason for fitting! I just had the duds.
Had new hose clips fitted by Pedders Darwin, Still leaked, Took bags out fitted short hose and valve to test found valve fittings faulty.
FollowupID: 379135
Reply By: Geoff - Sunday, Aug 07, 2005 at 20:18
Hope your right about the Firestone ones, i received mine last week and just finished putting them in the Crusier today. All ok so far but will see how good they are when i load the Crusier to the roof and then load the roof rack up full of the usual toys and gadets for the Fraser trip in September.
AnswerID: 124214
Follow Up By: Member - Jeff M (WA) - Sunday, Aug 07, 2005 at 20:42
I reckon you'll wonder how you did without them, they work great for me.
FollowupID: 379134
Follow Up By: the guardian - Sunday, Aug 07, 2005 at 20:48
Thanks for the reply Geoff,Have a mate has polyair and Firestone,Polyair front Firestone rear has had a good run with both,I feel Firestone are tougher for the job if you compare the two.
FollowupID: 379136
Follow Up By: Member - Jack - Monday, Aug 08, 2005 at 08:13
For Geoff and Jeff ....
A quick question on the Firestones ...
Are you supposed to drill out the hole where the bumper stops go, through which you thread the air line. It seemed to be to be a snug fit, and I was reluctant to drill it put in case I needed to refit the bumper stops (which I have now done).
I had some Firestones on my 80 Series and had quite a few problems with the air line pulling out of the bag, even though I had plenty of slack in the line. At present they are disconnected, but while they were working they were terrific. I am looking to perhaps replace them with a new set, because the air line connecter to the bag "went missing".
Thanks.
Jack
FollowupID: 379161
Follow Up By: Member - Jeff M (WA) - Monday, Aug 08, 2005 at 11:26
Jack, with mine I had to drill a hole in the bottom plate where the spring sits (right in the middle for the air line). Then of course file it out so there were no burs. With the bump stops you don't remove them altogether (well no ont the 4runner/install anyway) you take them out and haxsaw them off (trim them) then put them back in.
To prevent the lines getting pulled out, I've just done some good cable tyin! ;-) Havn't had the prolem (touch wood) but then again I don't have MAJOR articulation as I'm running standard shocks in the rear.
What I would suggest though is to us a few cable ties, but don't do them all the way up, leave them loose so that the air line can slide through them, that way it keeps the lines out of harms way (exaust, springs etc) but still allows them plenty of movement when required (articulation).
"because the air line connecter to the bag "went missing". "
Are you talking about the airline it's self? With mine the air line was a hard plastic polyutherane type hose that didn't have any ends at all on it, it just simply clicked into the bottom of the bag. (was a bloody mongral to get out again too!) Why did I do and was playing with it at work (when they first arrived) and hadn't read the instructions and clicked it in.... Then thought... Hmmm, oops. LOL
FollowupID: 379182
Follow Up By: Wayne (NSW) - Monday, Aug 08, 2005 at 12:16
Jack,
The hole where the bump stop was bolted in has to be drilled out to at least 44mm. The bags move around a lot and if this hole is not big enough problems will accrue.
I had a set on the 80 Series for 7 years and didn't have a problem. BTW I never let the bags go below 10psi. This stops the bag from rubbing on the springs and also stops small stones getting caught in between the coil and the bag.
Wayne
FollowupID: 379191
Follow Up By: Member - Jack - Monday, Aug 08, 2005 at 12:33
Thanks Jeff and Geoff:
That was the mistake I made in not drilling out the bump stop hole. As a result it was a bit tight on the airline and it kep pulling out the line. It eventually pulled out out the little brass coupling ("went missing") and now they are no use.
No fault of Firestone, but the installer (me).
I think I will get a new set from Trucksprings and drill that hole out.
Greatly appreciate your collective feedback and help on this.
Jack
FollowupID: 379194
Follow Up By: Member - Jeff M (WA) - Monday, Aug 08, 2005 at 12:43
You can buy seperate bags (spare ones) from Trucksprings too, might be a cheaper option.
FollowupID: 379198
Reply By: the guardian - Sunday, Aug 07, 2005 at 20:57
An amendment to my previous statement,the brass valve to bag fitting was faulty not the valve itself.
AnswerID: 124218
Reply By: Member - Phil B (WA) - Monday, Aug 08, 2005 at 04:54
I have had my polys 14 years and not a problem - some of the best money I've spent. I recommend them highly.
AnswerID: 124235
Reply By: Michael ( Moss Vale NSW) - Monday, Aug 08, 2005 at 06:40
Yeah, you would think they would just replace them and get good feedback instead of negative feedback on this forum. I have always said they are overpriced for what they are. Maybe the prosess is complicated or time consuming but i still cat see $300 in them. Truck springs in the USA can sell you a set for about half the price. Why? Michael
AnswerID: 124236
Follow Up By: Red GQ - Monday, Aug 08, 2005 at 11:24
Regarding buying from Truck Springs in the US. Are the model numbers etc on the Aussie web sites the same as in the US?? I am in the process of getting bags and dont want to order the wrong ones. In the US they dont seem to have Nissan Patrols??
FollowupID: 379181
Follow Up By: 120scruiser - Monday, Aug 08, 2005 at 13:03
I have heard you just ring them up with the height in side the springs and the diameter and they will send the right ones.
I wouldn't mind a set for my 120 prado, they are lexus's over there but a bit iffy.
It would be great if somebody already had a part number please?
FollowupID: 379203
Follow Up By: Michael ( Moss Vale NSW) - Monday, Aug 08, 2005 at 16:14
Gawd!!! me engrish aint good t'day!!!
FollowupID: 379225
Reply By: Member - Brad G (SA) - Monday, Aug 08, 2005 at 23:33
For info. My Firestone Riderite's did over 100,000 km's on my R9 and I have just fitted them to my RA. Simple matter to fit, remove bump stop, replace with Riderite's.
Cheers Brad
AnswerID: 124387
