Apparently you can fix sidewalls
Submitted: Monday, Jul 18, 2005 at 13:22
WheelTravel
Following my post yesterday of popping the bead, it turns out there was a little nick in the sidewall. The bloody champion at Tyrepower
Brighton...
Adelaide, was really helpful and spent time with me discussing fourbies touring and tyres as he has an awesome early model 100series.
He then sent me to a specialist across town who repairs sidewalls.Apparently he (the specialist) has been doing it for 40 something years, and they guaranteed me the tyre would be fine. There is special machinery and heat treatment and all sorts of stuff that is involved. Cost is $35.
He mentioned that a lot of the tyre centres tell people "nah mate it's in the sidewall, buy a new one" then send it off to him to fix and then they sell em 2nd hand!
So I'm pretty happy. And can highly reccomend the Tyrepower in
Brighton.
Anybody else heard of this treatment?
Reply By: Voxson (Adelaide) - Monday, Jul 18, 2005 at 13:39
who across town?
120917
Follow Up By: WheelTravel - Monday, Jul 18, 2005 at 17:04
Seaton Tyrce Centre
376019
Reply By: TerraFirma - Monday, Jul 18, 2005 at 15:53
Intersting, I was told it was illegal in
Melbourne and all I had was a screw through the sidewall, tyre was 3 days old.. Ouch it hurt.. If thats the case I still have my old tyre and I'll get it fixed in
Melbourne if anyone knows where..?
120944
Follow Up By: Truckster (Vic) - Monday, Jul 18, 2005 at 16:05
Yea there are
places that will patch sidewalls.. its pretty common with comp dudes. specially when their tires are $400+ each.
Ask on outerlimits dudes there get it done
376000
Follow Up By: Johnny boy - Monday, Jul 18, 2005 at 20:12
When I was doing my time as APP MECH I was also told to patch the inside, drop a heavy duty tube in and advise the customer to only run it as a spare or at best on the rear ( blow outs on your fronts make steering a bit hairy) but that was about 20 yrs ago, now my brother inlaw who has been in the tyre Ind for about 15 yrs says that its not allowed???? go figure.
Regards JB.
376050
Follow Up By: BenSpoon - Wednesday, Jul 20, 2005 at 12:02
Had a mate last year get 4 of his brand new MT/R sidewalls stabbed with a knife by somebleepoff clown in
Perth- I almost pity the fool that would have been sweating trying to pop them. EVERY tyre repair
shop we went to said a clear NO. At $1600 value we spent 6 hours trying.
I recall some saying it was illegal to repair sidewalls, and others said their company policy wouldnt let them touch it. I have also copped the same answers in a number of towns and cities from stakes (large and small) in sidewalls.
Again, the only repair we could effect was a large patch inside, and run the rubber with an inner tube and as a spare.
Not one
shop mentioned any alternatives or options for repair.
376323
Reply By: Willem - Monday, Jul 18, 2005 at 16:15
Yep I have a torn inside whatever on an STT(line bulge on outside), and my tyre man said he would put a gater in it for me which should last the life of the tyre
120951
Follow Up By: Member - George (WA) - Monday, Jul 18, 2005 at 17:59
Hi Willem,
Excuse my ignorance, but what is a gater.
Another form of sleeve ?
376031
Follow Up By: Willem - Monday, Jul 18, 2005 at 18:18
Hi George
It is a large, thick, rubber patch you can buy from a tyre
shop to put on the inside of your tyre if the sidewall has been cut. Mainly used on split rim tryes. Out here in the bush they have been called gater's for years. Maybe it has a fancier name now. Hope this helps. :o)
376033
Reply By: geocacher (djcache) - Monday, Jul 18, 2005 at 16:17
We holed two sidewalls in two Coopers with minute holes on the Canning trip. Burnt Mulga twigs are like nails!
Beaurepaires in
Scarborough Rd,
Perth said uh uh. Company policy, we can't repair it. Go to the Tyrepower who sell Coopers up the road and they might.
Patched the sidewall & put a tube in and away we went.
The tube isn't a necessity but theres more flex in the sidewall and it's a big ask for the patch to flex at exactly the same rate as the sidewall and stay stuck so the tube is a really good idea.
Dave
120953
Follow Up By: WheelTravel - Monday, Jul 18, 2005 at 17:09
Hi Mate,
This is also what tyrepower said they could do, however what this other place is doing is different altogether. They are drilling out the
puncture, then getting softened rubber and bogging the hole, then putting a 2ply patch on the inside and baking the whole thing with compression and all other stuff too.
Whatbleepme off, is that other tyre centres will tell you your tyres ratbleep, charge you for disposal, and then fix the thing and resell it...probably. I'm only guessing.
376021
Reply By: Member - John C (QLD) - Monday, Jul 18, 2005 at 17:02
Had a similar side wall problem here in
Brisbane a few years ago.
My mechanic know of some one who does tractor tyre repairs. Quite common repair evidently. Bloke didn't recommend the tyre for hard off road use and touring, so ran the milage left on the tyre out around town and doing local 4wd trips. Put a new tyre on for a big trip.
120958
Reply By: Member - Phil G (SA) - Monday, Jul 18, 2005 at 21:14
I'll second what you say about
Brighton Tyrepower. Greg is a top bloke - been away with him on 4wd trips, and he's an excellent trainer and assessor. Knows everything about 4wd tyres too.
phil
121020
Reply By: Surf - Monday, Jul 18, 2005 at 21:33
I punched a round 2.5-3 inch hole in the sidewall of my Savero A/T at the top of Calcup
Hill, took it back to
Perth and went to Greenwood Tyres and they sent it off for repairs.
$30 later it came back good as new, with the stipulation that it was probably best to run it on the rear only due to the extra rubber used to fill the hole etc.
The tyre then went through Mt Augustus, Karijini, down the coast from
Exmouth to
Coral Bay without any dramas.
Its next trip was 8,000 km through central Australia, including the West MacDonnell 4X4 track, the old Ghan line, Meerenie Loop and back through the
Great Central Road, not to mention across the Nullabor via the Eyre Highway on the way over. No problems what so ever.
Got back to
Perth and found out that the tyres were delaminating so had to replace them, but the repair held up. Best $30 I've ever spent on tyres.
121025
Follow Up By: Surf - Monday, Jul 18, 2005 at 21:43
I think I meant the East MacDonnell Range 4x4 route
376091
Follow Up By: Member - Davoe (Widgiemooltha) - Tuesday, Jul 19, 2005 at 01:16
Funny how you can ask 2 people the same question and get 2 different answers I had savero at and they lasted about 5000k before destroying themselves on pretty easy dirt roads at about 80kph - you can imagine my thoughtds on them
376128
Reply By: Nudenut - Tuesday, Jul 19, 2005 at 07:57
i had a bfg which was staked thru the side with a 5/8 -3/4 bit of mulga at around 5-10K....Bob Jane at glynde had it fixed and it lasted the distance
one could hardly pick the repair
dont know where they had it fixed
121057
