Swags again - water aspects
Submitted: Saturday, Jul 16, 2005 at 20:20
Mike Harding
I've been hosing down my new swag in order to waterproof it, according to the instructions. Actually the
Melbourne weather has been doing most of the work for me today.
I put a blue tarp, which is larger than the swag, underneath it before the soaking exercise commenced so
water has fallen on the tarp and flowed under the swag where, no doubt, it has pooled. Now as the tarp is (more or less) waterproof but the underside of the swag is canvas and will absorb
water (I assume?) does this mean those pools of
water will, eventually, soak through into my bedding?
If that is the case, is it better to put the swag directly onto the ground without the tarp underneath?
Mike Harding
Reply By: Lone Wolf - Saturday, Jul 16, 2005 at 20:25
Cut a tarp say 50 mm. smaller all around the footprint of your swag. The tarp will only stop cuts & tears, which is all you want it to do.
Wolfie
120673
Reply By: 120scruiser - Saturday, Jul 16, 2005 at 20:37
The bushwakker swag doesn't have a canvas bottom.
It has the polyurethane I think plastic type base. No tarp required just straight on the ground.
120674
Reply By: Moggs - Saturday, Jul 16, 2005 at 20:49
Probably a good idea to take the foam mattress out of the swag while you waterproof the canvas.
As for long term protecting the base. I had a canvas blind made for use at watercrossings with tabs sewn around the edge for securing. I use this folded under the swag when
camping on rocks / dirt. If you are
camping on grass I wouldn't bother with anything.
Just on the canvas blind - most used thing I have when offroad/
camping - ideal for a picnic rug, groundsheet for the swag, mat for when crawling under the vehicle, shade, windbreak when used with the tarp,
seat cover when muddy etc.
120677
Reply By: Member - Davoe (Widgiemooltha) - Saturday, Jul 16, 2005 at 20:50
Put swag on edge of tarp and when tarp is doubled over the swag like you would for heavy weather it should let
water onto the dirt alongside the swag and not onto the tarp letting it go under. Alternatly I also have a simple cheap setup that lets me put an awning off the side of the 4by to give somewhere to sit in heavy weather and you put the swag under it nice and dry. v quick to set up (if need be) and less than 30 bucks. But fair dinkum I reckon you worry too much the only damp sleep i have ever had in my swag was when I left it open during a rain storm
120678
Reply By: Rosco - Bris. - Saturday, Jul 16, 2005 at 21:43
I thought about this but haven't tried it yet ... How about 6 of those holed foam rubber mat thingys.
Add to the comfort and keep you off the wet ground, whilst letting the
water through ?
Thoughts ??
120692
Follow Up By: Member - John (Vic) - Sunday, Jul 17, 2005 at 00:25
Rosco I use these foam things without the holes as a under-mat / additional mattress / additional insulation. Works real good also protects against sharp rocks etc.
I have a waterproof bottom in
mine as standard from
Southern Cross same as the base of their tents.
375801
Follow Up By: Eric from Cape York Connections - Sunday, Jul 17, 2005 at 14:36
Wheres that red claw from rosco.
It would feed the whole family.
All the best
Eric
375848
Follow Up By: Rosco - Bris. - Sunday, Jul 17, 2005 at 15:10
Bloody beauty isn't it mate.
Got it at Lakefield NP. If I recall it was at 12 Mile
Waterhole, along with a whole swag of snapping handbags, esp a big mongrel about 3.6m.
Got a few good snaps of him too. Have to put it up in the piccie section one day.
Cheers cobber
375854
Follow Up By: Eric from Cape York Connections - Sunday, Jul 17, 2005 at 16:51
Did you get it in pot or with a scoop and what did you use in it.
I have used spuds but you may have a secret weapon.
All the best
Eric
375859
Follow Up By: Rosco - Bris. - Sunday, Jul 17, 2005 at 20:20
Maaaate
This is secret men's business .... don't let the cat outa the bag.
Got yarning to a dusky bloke in the
Laura pub .. top fella.
Anyway he says ... try 2 bits of meat ... 1 fresh and the other .. throw it into the fire for a few minutes .. get it all charcoled and crappy.
See how ya go... Tried both in separate TRAPS .. the blue collapseable jobbys.
Fresh meat ... no luck. Charcoal one ... viola.
Also tried spuds ... raw, baked any old how.
Charcoal meat did the trick .... not bad for a vege shrimp heh??
375883
Follow Up By: Member - Davoe (Widgiemooltha) - Monday, Jul 18, 2005 at 22:22
Am I going blind (my mum said this would happen if I didnt stop) but it looks alot like a cherubin rather than a redclaw. Unless it is local dialect as I thought cherubin were the northern version of freshwater shrimp on steroids and redclaw were like a marron/yabby except with red claws (and they live up north)
I figure there must be a trick to catching whateveritis that you have as i found you cant just throw out a yabby net and come back an hour later and find it full coz they dont like to share food or something
376105
Follow Up By: Rosco - Bris. - Monday, Jul 18, 2005 at 22:46
Mate
I also thought it was a shrimp on steroids ... but wasn't about to question that which I knew little about.
As for my secret tricks ... I reckon it was more bloody arse than anything.
Cheers cob
376114
Reply By: Truckster (Vic) - Sunday, Jul 17, 2005 at 00:19
If it looks like rain, I usually sleep next to the front of the car, and run a blue tarp off the top bullbar rail down to the ground..
Water runs over.. This is what I do with the 2 man tent too. works
well. Also works as windshield.. if it doesnt look like rain, then sleep next to the rear of car for wind shield...
120716
Reply By: rob&kev&roo - Sunday, Jul 17, 2005 at 09:06
As said above the foam mat thingies. we use 3 under each swag much more comfy than straight on the ground.
120742
