size of replacement tank
Submitted: Wednesday, Jul 13, 2005 at 19:11
bob007
does anybody know what the largest capacity fuel tank is to fit a 2002 dual cab hilux is and if so where from and how much? as i am in the market for one now.
thanks bob
Reply By: Greg Harewood - Wednesday, Jul 13, 2005 at 19:36
Well not sure what the largest is - use to have one with 120l tank - ORE brand I think, but sure there are others. I think it is also possible to bolt on another standard 70L(?) tank to make 140L - unsure about details.
120203
Follow Up By: bob007 - Wednesday, Jul 13, 2005 at 19:41
i have also herd this but you must shift your large muffler and i am unsure about a filler as it is a ute body
375256
Follow Up By: angler - Wednesday, Jul 13, 2005 at 21:15
I fitted one to my Hilux some time ago using another tank of the same model. I just turned it around and mounted it on bits that were already there. I put in a switch that changed over the guage and the tap at the same time. It worked just fine, I did have to re-route the exhaust pipe a bit and that was done at the same tme. Fairly easy if I remember rightly. The Hi lux is long gone, about five cars ago.
375288
Reply By: Member - Trevor R (QLD) - Wednesday, Jul 13, 2005 at 21:02
bob,
try out of town 4wd. oot4wd.com.au I think.
Good reputation.
Trevor.
120232
Reply By: Jason B - Thursday, Jul 14, 2005 at 21:53
G'day Bob,
I have the 2004 Dual Cab Hilux and had ARB
Rockhampton fit a 116L tank in place of the standard one, the tank cost $830, fitting cost $210 and Compliance Plate (QLD) was another $66. I thought I got a pretty price at the time, along with all the other gear I got put on.
I have heard others mention 120L tanks but I couldn't find anyone that sold them when I looking.
Regards,
Jason
120430
