Friday, Jul 01, 2005 at 20:41
The Hummers have either a NA 6.5l diesel or the same capacity engine with a turbo. 4 speed auto trans, contant 4wd, locking Ziekel torsen diffs front and rear. They also have dual fuel tanks. The main 90l and a 45l aux (I think)
The turbo motor only puts out 10 more hp but double the torque.
I'm not sure on the actual tow rating, the Humvee has a 1500kg unbraked, cross country (off road) and nearly 3 times that on road. Australian regs will not allow the trailer to exceed the towing vehicle.
It would pull 2.4 Tonne ok.
It is not geared for high speed running rather a plodder.
They are not a particularly fast vehicle but the ride is superb on rough ground and tracks. Very stable due to the very low C of G, wide track (2100mm, 200mm wider than a 100series) and long wheelbase (130").
I get 450 -500 k's out of 75-80 litres (which is the same as my troopy) in the Humvee, a Hummer may use a bit more as it weighs more. Mind you if you want to travel at contiinuous high speed (110+) then it will guzzle it due to the total lack of aerodynamics, excessive use of the go pedal will achieve the same result.
373646
