Earth strap on nissan
Submitted: Sunday, Jun 26, 2005 at 23:20
Dwayne
Hi all.
Just wondering where you would fit the chassis to body earth strap on the 1999 Nissan GU to stop the sub tank light coming on.
Can I put it anywhere or is there a certain spot to put it.
Reply By: Member - RockyOne - Thursday, Jun 30, 2005 at 09:10
Bit off subject maybe! ..Remember that on "jump starting",most of my vehicle manuals state to put (red) positive lead onto + positive (red) terminals of sender/receiver batts..However,for the (black) - jumper lead,clip onto sender (donor) batt terminal.but,do not put other cable clamp onto vehicle - neg terminal..Put that clamp onto a good"earth" point of the motor (the zinc plated lifting eyes etc)..Before putting above into practice,read the instructions for your rig.Mistakes can be expensive,or if out in the bush at the time,distasterous..Helps? RockyOne (Adopt the habit of fitting black earth lead first,then,the red one)
118201
