Tuesday, Jun 21, 2005 at 18:48
OK. You've opened a can of worms.
You are right, the 3.0L (1KZ-TE) is the only way to go IMHO. But they still can suffer from overheating, but not because "they are not built for australian conditions". They overheat because they are neglected and not maintined properly. Because they are built for cooler climates they do tend to show signs of neglect sooner in the cooling system as there is less margin for error (so to speak).
We overload our poor surf evertime we go away, we live in WA and have HOT summers, we don't pussy foot around and we have now solved ALL of our overheating problems without doing any major modifications.
Things to do when you pickup your new surf:
1. Do an oil and filter change (you should do this with ANY new second hand car).
2. If you feel up to it change: air filter, diff's and tranny/transfer oils too. (why not).
3. Get the radiator to a specialist and get them to re-core it, get the system pressure tested. (
mine had pin hole leaks that you couldn't see that were causing the system to loose pressure when worked, therefore over heat). MAKE SURE YOU RUN TOYOTA LONG LIFE COOLANT (the red stuff).
4. While the Rad's out get the Viscous Clutch Fan re built. (squeeze some special silicone into it).
5. If it's an auto (which I WOULD recommend, they are great) get a third party oil cooler fitted for the transmission (if it doesn't have one already). They are realitivly cheap and you'll find that the heat from the standard oil cooler in the bottom of the radiator is what causes most of the heat build up in your Rad. It will also make you tranny last longer if you work it hard a lot.
6. MAKE SURE YOU AIR FILTER IS ALWAYS CLEAN!
7. If it has a Safari
Snorkel, ensure it doesn't have a restrictor in the top of it (a big metal washer). This will restrict the air flow and cause you motor to run rich. A Diesel running rich produces smoke and runs hot.
Now this may seem a lot, but really you should be doing most of those to ANY car you buy.
The surf is comfy, very nice to drive on road and off, very capable, the 3.0L has plenty of go and they are
well priced. The 1KZ-TE motor is nice to work on and parts have been easy to get and
well priced so far (touch wood). The Auto is very responsive and just "the bomb" off road, I'll never go back to a manual 4by.
Click on my Rig Pic (avatar) to see the surf mod's we've done.
116760
Follow Up By: ZTG - Thursday, Jun 23, 2005 at 09:02
Jeff,
thank you very much for the detailed advice, will be very usefull information.
Zach
372492
