Talawana Track - Midway Well
Submitted: Wednesday, Jun 15, 2005 at 12:32
ThreadID: 23889 Views:1882 Replies:4 FollowUps:2
Does anyone know if the bore / windmill (I believe it is known as Midway Well) on the Talawana Track half-way between the Canning Stock Route and Windy Corner is operational (that is, can I get drinkable water from it)?
Reply By: Footloose - Wednesday, Jun 15, 2005 at 13:03
Iwas sure that this came up in a previous post that I can't find quickly. AFIK the answer was no, the well is in bad shape.
AnswerID: 115867
Reply By: desert - Wednesday, Jun 15, 2005 at 14:45
If you mean the original Midway Well, then no it is silted over and not servicable. If you mean the windmill and tank on the track a little further to the east, then yes, good water can be had from here in a large tank.(10,000 gals).Water is potable.
AnswerID: 115876
Follow Up By: andy - Wednesday, Jun 15, 2005 at 15:27
how far away from the original midway well and from the track?
FollowupID: 371458
Follow Up By: desert - Thursday, Jun 16, 2005 at 13:05
The turn-off to Midway Well (approx 85kms east of CSR) is virtually next to the track to the windmill and tank, a couple of hundred metres at most from memory, follow that in for about 5-6 kms and you will see the tank and windmill and the remains of somebodys attempt at a vegetable patch in the desert!
FollowupID: 371603
Reply By: Member - George (WA) - Wednesday, Jun 15, 2005 at 21:33
Windmill Tank is 6 km off the Tallawana track
AnswerID: 115945
Reply By: Cam A. - Tuesday, Jul 05, 2005 at 23:07
I was there 3 weeks ago, the tank is dry. The windmill is turning but no water being pumped.
Nearest potable water would be Georgia Spring.
Burppp
Cam
AnswerID: 119027
