Vibration 2005 GU
Submitted: Friday, Jun 03, 2005 at 11:33
ThreadID: 23555 Views:2476 Replies:5 FollowUps:6
Just wanting to know if anyone else with a new GU Patrol has exerienced any accelerator peddle vibration when travelling at speed between 100-110km?
Reply By: Leroy - Friday, Jun 03, 2005 at 12:06
Which engine and what sort of vibration?
Leroy
AnswerID: 114222
Follow Up By: TJ HACH - Friday, Jun 03, 2005 at 15:21
The 3.0 litre Diesel. The vibration is intermitant and can be felt through the sole of my shoe through the accelerator pedal, and only occurs at speeds over 100kmh.
FollowupID: 370214
Reply By: Truckster (Vic) - Friday, Jun 03, 2005 at 12:08
auto or manual
AnswerID: 114223
Follow Up By: TJ HACH - Friday, Jun 03, 2005 at 15:22
It is a manual.
FollowupID: 370215
Reply By: Michael ( Moss Vale NSW) - Friday, Jun 03, 2005 at 21:31
Yep, Sure do.I have the same problem, I was about to post the same. I have a 2003, 4.2 tdi. Started happening at 95,000ks,, now at 117,000ks.. Starts to vibrate at 2100rpm and fades out at 2500.. in all gears, Its driving me crazy,,, errr crazier!!! Nissan says they cant notice it.. The guy who test drove it must have no bone in his right leg.. My vehicle has a cable and so if something vibrating i can understand but the 3.0L does not have a cable... I am going to check if a weight is missing of the tail shaft, other than that it could the clutch plate with a piece missing off it. Michael
Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.
AnswerID: 114292
Follow Up By: Michael ( Moss Vale NSW) - Friday, Jun 03, 2005 at 21:35
Starts about 100ks per hour, The 3 litre has a higher diff ratio so it appears to be in the same rev range.
Patrol 4.2TDi 2003
FollowupID: 370258
Reply By: Member - Davoe (Widgiemooltha) - Saturday, Jun 04, 2005 at 05:25
Are the hubs locked in? I ave seen a few cruisers that get front tailshaft vibrations when being driven in 2wd but the hubs locked in
AnswerID: 114308
Follow Up By: TJ HACH - Sunday, Jun 05, 2005 at 18:36
No, the hubs are not locked in.
FollowupID: 370358
Reply By: Farside - Monday, Jun 06, 2005 at 07:49
I have a 2005 GU 3.0l manual, and it very smooth at speed. I have only done about 6000km. I have noticed that when ever I have pulled anything apart to inspect or modify that the bolts are never that tight. I even had the dealer tighten up my back suspension after I could hear a knocking noise.
A question for you, does you windows rattle when they are half open and you are traveling on a dirt road? The glass is not sandwitched very well in the upper half of the door.
Angus
AnswerID: 114505
Follow Up By: Leroy - Monday, Jun 06, 2005 at 09:25
Windows rattling is a std GU feature.
Leroy
FollowupID: 370406
Follow Up By: TJ HACH - Monday, Jun 06, 2005 at 17:40
Angus, I have never has my windows half open on a dirt road so I don't know....I'll give it a go and let you know.
FollowupID: 370484
