Chescold fridge odour
Submitted: Tuesday, May 31, 2005 at 14:52
Black Jack
I have an older style Chescold, with the metal case and I have done all the mods suggested on this
forum (thanks Adam and co) it works fantastically. On 240v I have to turn the thermostat right down or everything freezes. Even 12 volt is fantastic - but there is an odour problem. I have not smelt it when it was in the pergola on 240 or gas, but when in the car... I had to turn it off. The odour may have been there while running in the pergola but the open area may have dispersed the smell.
I repacked new insulation around the heat exchanger. I spoke with a fellow south of
Brisbane who repairs Chescolds and he said he used ordinary roof insulation. I had some pink batts so I used that. I tested it for fire etc before putting it in. It is not burning. I've run it on 240 for 3 weeks, on gas for a week, but when I went for a long drive to
test it on 12 v the fumes were too much. The smell is strongest at the top of the flu, but may not be coming from the flu pipe, but the general area.
Has any one else repacked the heat exchange insulation? If so what insulation was used? Is it the Pink Batts that are the problem and is there a chemical in these?
Thanks,
Black Jack
Reply By: Marko - Tuesday, May 31, 2005 at 15:39
G'day Black Jack,
I made some modifications to an RC1180 3 way as suggested here. Owning a sheetmetal
shop coming upon insulation to re-wrap the flue was easy. However took it camping that weekend and the smell - whew.
I replaced it with polyester insulation, 25mm thick, perforated foil faced insulation which we use for ductwork. So after that trip I came back, replaced the insulation with fibreglass and it worked a treat. Spend 10 days in the
Flinders Ranges and didn't smell a thing.
So in short the polyester insulation melts on the flu causing a terrible smell. I ended up putting back the insulation that was in it, plus a top up of 'fiberglass insulation'.
Marko
113746
Follow Up By: Black Jack - Tuesday, May 31, 2005 at 16:05
Thanks Marko,
I would say I used Polyester as
well. I'll have to go looking for fibreglass insulation.
Ta
Jack
369820
Follow Up By: Black Jack - Tuesday, May 31, 2005 at 17:06
Marko,
I've been down to the hardware store and made a few calls to some builder friends and no one has the correct insulation. I really don't want to buy a full bag, just to get a 300mm square piece. Where did you get your insulation? If you have the insulation at your work and are interested in selling some I'll post you off a cheque. I leave on the 19th June so I have to solve the problem asap.
Jack
369830
