Split rims for an 80 - how much?
Submitted: Monday, May 16, 2005 at 04:26
Member - Davoe (WA)
Got excited the other day when a bloke at work asked me if I wanted 5 split rims for my 80 but soon lost intrest coz he wanted $400 I will be going to
Perth soon and was going to try and chase some up but what are they worth? I would have thought about $40 each. In case any body is wondering I want them to mount 12 -14 ply crossplys on for bushwork COZ I AM SICK OF WRECKING TYRES AND GETTING FLATS and that is without even getting near the spots i want to go. Using these tyres last year we only managed to ruin 1 between 2 vehicles and that was using them primarily in extreme cross country (bushbashing) conditions
Reply By: bundyman - Monday, May 16, 2005 at 07:49
Davoe,
Mate, I still run the skinnies on my 75 series and am always on the look out for some spare rims. If you
shop around you should still be able to find some for $50 each but even they probably won't be much chop. I work in the mines too and we still run alot of 75 series vehicles and hence the demand for them is still there but there is very little supply due to the new 5 stud rims (What were Toyota thinking!!) But yes $100 is a bit rich. In a few years time I'll probably have a look at converting my cruiser to the 5 stud setup and then being able to pick-up the new type split sets for bugger all. Good luck.
Hughesy
111401
Reply By: Drew - Karratha - Monday, May 16, 2005 at 09:54
I have 5 split rims to suit an 80 series you can have (
well, for a carton...) - only thing is I am in
Karratha. Let me know if you are keen
Drew
111410
Reply By: mac1 - Monday, May 16, 2005 at 10:35
Davoe
Try the tyre dealers we used to run the nissan patrol rims and tyres on our HZJ 75 you might also try the nissan dealer as alot of them change them to "fats" and have the spits left. (used yards as
well).
Mac
111415
Follow Up By: Member - Davoe (WA) - Monday, May 16, 2005 at 20:29
tried them around 90 each
367861
Reply By: Member - Captain (WA) - Monday, May 16, 2005 at 11:50
Hi Davoe,
I have 4 split rims off my old 80 series. 3 are bare and on the 4th I have a 7.5R16
Dunlop tyre that was a second spare for the 80. My original idea was to use the rims on my van, but as I have the GU now they are just gathering dust and have done so for many years now.
The tyre/rim is now used as my 2nd spare on my GU, but have actually yet to use it. You are welcome to have the 3 rims and if you want the 4th, I just need a rim to use as a 2nd spare on my GU. I am in
Perth if you are interested.
Captain
PS. Also have a frame to mount a winch on the front of an 80 series between the chasis rails, free to a good
home.
111432
Follow Up By: locallaw - Monday, May 16, 2005 at 20:11
Gidday Captain,If you havent parted with the winch mount I would be interested in acquiring if possible.I have a winch but cant afford the winch bar.
Thanks Locallaw
367859
Follow Up By: Member - Davoe (WA) - Monday, May 16, 2005 at 20:28
Sounds good I have 1 splittie as a second spare so that would gve me 4 which is probably all i would need as I would still have 2 radials as spares. also I often just pull the tyre off when i get a flat, fix it and put it straight back on. takes about 1/2 hour with splitties including reinflating. Also you only need to take donuts instead of the whole spare as tyre fitting is easy with splitties. I will send you a MM if I end up in
Perth this break TA
367860
Follow Up By: Member - Captain (WA) - Monday, May 16, 2005 at 22:09
Hi locallaw - your welcome to the winch mount. Its not a full bar but a cradle that bolts onto the front chassis behind the bumper/roo bar with the fairlead bolting onto the roo bar. This one fits a Ramsay 8000lb winch, but would easily take a different size by redrilling the holes. Email me on "mpeaccock at bigpond dot net dot au" to organise things, I can send a
pic if you want.
Davoe - No worries, either member message or email me using the above address.
Captain
367882
Follow Up By: Member - Captain (WA) - Tuesday, May 17, 2005 at 12:06
Just spotted a mistake in my email address above, sorry. Its "mpeacock at bigpond dot net dot au"
Captain
367956
Reply By: Mark- Monday, May 16, 2005 at 17:53
Just bought four from a local tyre place (1st one I tried) for $25 each. Virtually brand new - they had a shed full of them from people who change over to 'fats'.
111477
Reply By: 80scruiser - Monday, May 16, 2005 at 20:16
Try E Bay
I bought 4 for about $80.00.
111504
Reply By: Steve - Monday, May 16, 2005 at 21:19
Bought ten recently for $40...all never been on road !!
111521
Reply By: BenSpoon - Tuesday, May 17, 2005 at 00:32
Davoe-
Wait a bit for the 4WD club newsletter- Gary's got a set of 6 with average tyres on em for $100-he traded in his 80 for a GU (poor bloke)
111563
Follow Up By: Member - Davoe (WA) - Tuesday, May 17, 2005 at 01:43
havnt got a number for him do you?
367920
