Tuesday, Nov 05, 2002 at 01:00
For those that asked for the GU.
Took me around 5 hours but they are finally in. To get it to fit, I had to:
1. Remove the 4 tie down points,
2. Trim 10mm from either end of the section 6,
3. Move section 1 forward approx 65mm to pick up the child restraint
points and drill holes to secure the front of the drawers,
4. Cut the drivers side mounting point of section 2 back so it is flush
with section 5 (keep the passengers side mounting point),
5. Move section 2 forward approx 15mm to pick up the rear left and rear
right tie down points and drill holes to secure the rear of the drawers,
6. Cut approx 30mm from brackets 9a +9b (I haven't done brackets 8a + 8b yet as you will have to cut off the captive nuts to fit),
7. Install and fit sections 1, 2, 3, 4, 5, 6, 7, and brackets 9a + 9b
including drawer stops,
8. Fit sections 10 and 11. I found 10 was a very tight fit and sits flush
with the left rear door,
9. Trim approx 75-90mm from section 12b. I did this by starting at the
front (at section 6) of the cargo system and measuring from the centreline of section 4 to the drivers side trim and then slowly work rearward taking measurements as I went. It was very easy to do in the end. One I got all the measurements, peel back carpet and cut it all, I measured section 13b and cut section 12b to accommodate,
10. Trimmed the carpet and reglued using spray adhesive. Installed
section 12b onto cargo system,
11. Do the same for section 12a. I haven't allowed for the installation
of section 13a yet until I decide what to do about brackets 8a + 8b.
12. Everything should be done.
Things that I noticed:
a. Most holes line up except for sections 12a and 12b. Some of the holes
are misaligned and may need redrilling. Use a screwdriver pushed into the hole and leverage to align.
b. Back of cargo system just touches the back
seat.
c. Front of cargo system just touches the rear doors at section 10 and 11.
d. I don't like the huge holes in section 7 that house the drawer locks.
Will have to think up a better system (too much play),
c. Have lots of bandaids on hand - I think I cut myself about 23 times.
Have fun
David Christensen
http://
home.gil.com.au/~david/
8226
