Wednesday, May 04, 2005 at 08:18
Hi essjay,
Besides the comments above:
Yep, does lift front wheels. Rear LSD helps.
Friend just bought a 99 3.5l petrol with 135,000k, 6 months ago off a dealer.
Starting to find the problems.
The vacuum control to the front diff is playing up a little. Keeps dropping into 4wd or is hard to engage/disengage. Look under the bonnet on the driver side mudguard for the two little vacuuum switches with the small hoses leading to them.
To
check engage and disengage 4wd a few times while driving, should happen reasonably smooothly with the dash lights only flashing a few times. Flashing lights means that the 4wd system isn't in yet, but waiting for the right moment to mesh everything. It should only take a few seconds. You can change from 2wd while travelling to 4wd high unlocked centre diff at higher speeds like 80km/hr, but might result in a clunk. Read the instructions.
He also fould quite a few deep scrapes under the rear diff, and a good dent in the front of the fuel tank. Assume you will be doing a good under body
check anyway.
Make sure the timing belt has been done every 100,000k.
Just did an oil change for the the g/box and diffs and it has improved. Wasn't too bad before, but it seems an area poeple miss servicing at 130,000 as per the book.
A click/clack sound has developed which could be front CV joints or lower ball joints. Or might just be something simple. Don't know yet.
I find he has more torque down low between idle and 1500rpm than my diesel, until my turbo cuts in :-).
I have a 96 2.8 diesel (238,000k) and it suits us fine for town use and the one or two trips a year out west, and a bit of 4wding around Brisy. Hasn't been on
the beach too often, but the petrol would be better than the diesel on the soft sand.
I just had to replace the aeon rubber springs in the rear coils. Gone completely.
Well for $300.00 plus for the pair from Mitsubishi, I just put in airbags.
109570
