best coolant for 80 series diesel
Submitted: Sunday, May 01, 2005 at 20:55
ThreadID: 22554 Views:7995 Replies:6 FollowUps:2
what is the best coolant to use in an 80 series diesel also i am up for a new set of tyres soon what would you recommend ihave desert duellers at the moment and have got over 90000kms from them so am a thinking of getting them again 97% bitumen 3% dirt thanks for your help
Reply By: Exploder - Sunday, May 01, 2005 at 21:48
Gday scott
Why not use the Toyota stuff isn’t it a special red coolant?
Or just use another Quality coolant. Just make sure it meets Toyota’s cooling system protection specifications
I would stay with the desert duellers they are a proven performer and if you are happy with them why change.
AnswerID: 109141
Follow Up By: Member - Davoe (WA) - Tuesday, May 03, 2005 at 18:36
thats NOT coolant just corrosion ininibitor dont confuse the 2
FollowupID: 366096
Reply By: Peter 2 - Sunday, May 01, 2005 at 22:05
I'll second the genuine Tojo stuff, I used it for 20 years (with recomended changes at correct intervals with absolutely zero problems.
AnswerID: 109143
Reply By: Footloose - Monday, May 02, 2005 at 08:33
The only stuff to use in your cooling system is the Tojo red stuff according to all the mechanics that have ever worked on mine.
Can't comment on tyres, I use the Kelly brand. The LT ones are great for the dirt, but there are better tyres for the tar.
AnswerID: 109168
Reply By: Member - Phil G (SA) - Monday, May 02, 2005 at 12:42
Likewise, I'd only use the genuine Toyota coolant. If you mix coolants, without neutralising and flushing out the old coolant, precipitation can occur and block the radiator.
AnswerID: 109213
Reply By: Member - Karl - Monday, May 02, 2005 at 12:56
Scott,
I have Desert Duelers - same percentages as you and I like them. I have had them on all of my 4WDs and never have a problem.
As far as coolant goes - I get my 80 Series serviced by TLC here in Perth and they make and supply their own coolant when they do work on your car and provided free top ups for you to carry around. Not sure of the brand but it is green in colour. They swaer by it.
I have used the Nulon brand previous to this and found it okay, especially the anti freeze for when I live in Canberra.
Just make sure you give your radiator a good flush - don't mix different brands as some will react with each other.
Hope this helps.
Karl
AnswerID: 109215
Reply By: Member - Jeff M (WA) - Monday, May 02, 2005 at 13:11
Only one answer to the coolant and that is the Toyota LLC (as everyone else has recommened). Even Nissan owners use it, that's how good it is!! LOL
I had desert dullers and just traded them in on some Goodyear MTRS. There is NO comparison on dirt, the MTR's wipe the floor, but seeings as you said 3% dirt, might as well go the DD's.
AnswerID: 109221
Follow Up By: awill4x4 - Monday, May 02, 2005 at 19:32
Not this Nissan owner, I only use Tectalloy cooling products, they are comparable with and exceed OEM requirements.
As a good excercise for those looking at coolants, give the bottle a shake and check to see just how quickly the bubbles that are made settle down. Those coolants which settle faster are the ones most resistant to cavitation, Tectalloy is one of the fastest.
Regards Andrew.
FollowupID: 365945
