Pajero gear box
Submitted: Monday, Apr 11, 2005 at 15:24
chops
I have a 99 Pajero Exceed that I have taken onto
the beach just the once. After driving for about 15 minutes in semi tough conditions the gearbox heat warning light came on. We stopped and waited for a few minutes and it went off again. I have heard that there is a sequence for engaging 4WD in the Pajero's is this true or do I have a problem with my gearbox?
Reply By: pjchris - Monday, Apr 11, 2005 at 16:56
If you mean putting it in low range...not really.
2WD to 4WDH (4WD high Ratio)
Just move the lever. This can be done at speeds up to 100km/hr.
4WDH to 4WDHlc (4WD locked center diff)
Again just move the lever. Not sure of the speeds..It's on the label on the Drivers door.
4WDHlc to 4WDLlc:
Stop!.. Move the lever to the neutral position. Then move it to 4WDLlc. Drive off.
Sometimes you need to reverse several meters to unlock the diffs, but you shouldn't need to do this to lock them...I certainly never have and I've had an NH and an NM.
106173
Follow Up By: pjchris - Monday, Apr 11, 2005 at 17:00
ps.
Yours would be an automatice, Yes?
It is not unusual for autos to overheat in sand as the gearbox is working very hard, but I would
check the Auto trans cooler for blockage and probably give it a drink of noce clean Trans fluid (A complete change). Maybe even get the system checked over as 15 minutes to overheat seems a bit short. Were you in High or Low range?
Others with more sand experience can probably give a better idea on wether High or Low is better etc...
363214
Reply By: MickeyJ - Monday, Apr 11, 2005 at 18:03
Mine did that on the sand too. Solution run low range in the dunes.
Mickey
106194
Reply By: Utemad - Monday, Apr 11, 2005 at 18:11
What tyre pressures were you running?
If you didn't drop them to an appropriate level (~20psi perhaps) then that could be the cause. Did your engine temp rise at all?
106198
Reply By: Peter 2 - Monday, Apr 11, 2005 at 20:33
In auto's you are better off running in low range to keep the engine revs up and keep the torque converter slip to a minimum. It is the torque converter slip that heats the fluid and leads to overheating.
A lot of auto 4wd's have very marginal cooling capacity in sand because the heat from the transmission fluid heats the radiator coolant up to the point where the engine overheats and then kaboom!
Earlier diesel surf's, jeeps (the engine management system shuts the engine down when they get too hot), pajero's and a few of the soft roaders and mid range 4wd's are especially susceptable to this problem. Most of the larger vehicles, cruisers and Patrols seem to be able to cope but any with partially blocked cooling systems will have trouble.
Check your ATF fluid for burning and if it smells burnt or has a brownish colour change it completely, usually easier and cheaper to have a trans
shop do it too.
If you want to do a lot of sand driving you may be advised to put synthetic ATF in as it handles heat better.
106231
Reply By: chops - Tuesday, Apr 12, 2005 at 08:34
Thanks to all that responded. This is the first time I have used a
forum and think it's just great. I have had experience driving in sand, that's why this was a mystery as I thought I was doing everything right, although I had never driven on
the beach with an auto. My tyres were deflated to about 15. I was in high range, which seems to be the issue with autos.
Thanks again for all the
feedback.
106305
Reply By: Sapper - Tuesday, May 10, 2005 at 22:29
Chops
Strange one that. Never had the problem and have driven many times on Frazer Is, as far as
waddy point and North of Noosa to
Double Island Point.
I never drop my tyres below 20 PSI. 16PSI is considered as low as you should go. I like to have some tyre pressures to play with if I get in trouble.
Sand driving relies on momentum. Hence High Range is ideal. Enjoy the experience and the Paj.
Sapper
110729
