Monday, Oct 14, 2002 at 00:00
The following is a list my brother and I compiled for a proposed lift to my 80 Series. He has already completed a 3" lift on his 60 Series.
Fan / Radiator shroud Fan will be in a lower position to the radiator, shroud base may have to be splayed.
Exhaust hangers-Some exhausts hang from the body, these may need extending.
Steering Joints-Loosen both universal joints on the steering shaft.
Gear shifters-Will be shorter and may clash with the hole in the floor. Fuel tanks-
Check for effects of body movement.
Brake lines-
Clutch line-
Throttle linkage / cable-
Heater hoses-
Wiring harness-
Speedo cable-
Hand brake cable-
Spare wheel-
Roo bar / headlights-Headlights will be higher and may cause glare. Water tanks-Inlet and outlets.
Hardware required Nuts and Bolts-Longer high tensile bolts. Spacers-number required 12?
Flashing-To keep fluid and mud out of engine bay and aesthetics.
Diff Breathers - lengthen or
check for effects of body movement.
A "Body Lift" search of this
forum should get you most other answers you will require
Coops
7394
Follow Up By: Royce - Thursday, Oct 17, 2002 at 00:00
Ah ha.... I recognize this list .... You sent it to me when I inquired a few months ago. I printed it out and used it as a guide while lifting my girl. It was great! I systematically worked through and had no problems, which is not normal for me! Thanks Royce
3472
