diesel 3.4
Submitted: Wednesday, Mar 16, 2005 at 21:10
hedevil
hi we have a toyota coaster camper, it has a 3.4 diesel with a schwitzer turbocharger. A few weeks ago while driving we stopped and when restarted engine there was a loud knock upon investigation the injector heads were replaced and the vehicle went
well for abot 300 km we went to go away last weekend and the same thing happened will start great and idle as soon as some exaleration is applied this knock appears. now its back with the diesel expert and he says injectors are fine has checked compression is fine has checked top end is ok has checked inlet exhaust appears fine says could be oulet exhaust blocked, im confused same symptoms as before injector heads done he says would be the fuel pump as fuel is getting to engine and black smoke comes with the exaleration as
well as knock, any technical comments would be appreciated max and carol
