Tappet clearance
Submitted: Monday, Mar 07, 2005 at 21:41
Pauly
G'day all any one know the tappet clearance for a TB42? should i do them when the engine hot or cold?
cheers Paul
Reply By: Brew69(SA) - Monday, Mar 07, 2005 at 22:28
If adjustment is being done after cylinder head or rocker arm service do it cold first then
check again after warming engine. Gap is .38mm. No 1 piston needs to be on TDC on the compression stroke.(ie. the position of the timing mark on the crankshaft pulley will be aligned with the TDC (0) mark on the timing cover and the two valves of NO 6 cyl will be rocking.....one closing and one opening).......Source
Gregory's service manual for GQ. Hope this helps.....Stuart
101513
