285/75/16 tryes rubbing at full steering lock
Submitted: Sunday, Oct 06, 2002 at 00:00
I have just purchased 4 tyres (285/75/16) for my Prado. At steering full lock they rub on the mud flaps. Does anyone have any suggestions as to what i can do to alleviate this problem. Would a 2" body lift help? any help would be appreciated.
Reply By: Bernie- Sunday, Oct 06, 2002 at 00:00
I looked at 260/75/16 and they are about 38mm bigger in dia. than standard issue. and not enough clearance I dont think a 2" lift would change much , if the body goes down and the
suspension is up u might rip of the flares try the "Prado site" u should get a good response from them yahoo "90scool "
7210
Follow Up By: Bernie - Sunday, Oct 06, 2002 at 00:00
The address is groups.yahoo.com/group/90scool
you need to register to get to messages
3291
Reply By: Fred - Sunday, Oct 06, 2002 at 00:00
Peter I think you should stick to the right sized tyres! The standard tyres on a Prado are more than adequate.
7211
Reply By: Malcom McInnes - Monday, Oct 07, 2002 at 00:00
Check the steering stop adjustments, if adjustments cannot be made , stick to the original tyres.
7213
7214
Reply By: steve - Monday, Oct 07, 2002 at 00:00
Get rid of them! If they rub now wait till you are at full lock travelling on rough ground.
7217
Reply By: Sambo - Monday, Oct 07, 2002 at 00:00
Peter, I have a 2000 Prado TX and have a second set of GXL steel wheels with 285/75/16 tyres fitted. I also have a 40mm
suspension lift and have no problems with them rubbing on my guards. Clearance is tight but still enough even under extreme 4wd conditions on full lock with
suspension fully compressed. If you really want to use them a 2"
suspension and a 2" body lift should allow you more than adequate clearance otherwise you will have to go back to original size. Cheers Tony
7224
Follow Up By: Bob Y. - Monday, Oct 07, 2002 at 00:00
Sambo,
If clearance is tight now, what happens when you get caught in a storm, on a blacksoil plain somewhere. You'll be cursing the 285's then. Regards, Bob.
3301
Follow Up By: Sambo - Monday, Oct 07, 2002 at 00:00
yes Bob that is very true but I am currently looking at a 4"
suspension lift or a 2" body lift which will alleviate any problems in that regards. Tony
3303
Follow Up By: Kev - Thursday, Nov 07, 2002 at 01:00
Hi sambo, did you speak to Toyota before you put your lift kit on to see how it effects your warranty on the running gear etc.
Cheers Kev
3976
Reply By: Peter - Monday, Oct 07, 2002 at 00:00
As they havent been on the road yet, i think i will try and return them to the supplier where i purchased them. If he wont take them back i will try the body lift as i already have a 2"
suspension lift. Thanks to you all for your input as it was most helpful.
Cheers Pete
7236
Follow Up By: Slunnie - Monday, Oct 07, 2002 at 00:00
Peter, Is it possible to use alternative mud flaps? Regards Slunnie.
3305
Reply By: Peter - Tuesday, Oct 08, 2002 at 00:00
Slunnie, The mud flaps are a molded type amd unfortunately dont look as if they can be replaced with an alternative type or repositioned. I have spoken to the guys at Tyre power and they will gladely exchange them for the smaller 265/75/16. Thanks everyone for your help.
7270
Slunnie, The mud flaps are a molded type and unfortunately dont look as if they can be replaced with an alternative type or repositioned. I have spoken to the guys at Tyre power and they will gladely exchange them for the smaller 265/75/16. Thanks everyone for your help.
Pete
7271
Reply By: RHYLDON - Thursday, Oct 17, 2002 at 00:00
a coupled of things you could look at
1. 2" body lift 2. different wheels with a different offset
i put 32" on my 85 pajero with 2" body and lift kit and different
wheels with different offset. goodluck
7524
