Nissan Terrano 1991 Clutch Fan
Submitted: Tuesday, Mar 01, 2005 at 18:45
ThreadID: 20883 Views:1878 Replies:3 FollowUps:1
Could someone please advise how to top up the clutch fan with silicone and what is the best thermostat to have in place.Currently based in the Pilbara and although under normal driving everthing temp wise ok but have some trips coming up that will require towing and I need to be prepared as daytime temps continue to be 40+.
Reply By: theshadows - Tuesday, Mar 01, 2005 at 19:23
use toyota fluild....however the consense is dpnt.....just replace the whole clutch and water pump at the same time.its a one piece unit.
shadow
AnswerID: 100708
Reply By: Member - Oskar (Bris) - Tuesday, Mar 01, 2005 at 20:24
Filling with fresh silicone oil improved the clutch on mine quite a lot.
my email is "oskarnatskiat hotmaildotcom" if you email me I can send you some pics and some details.
No problem
Oskar
AnswerID: 100712
Follow Up By: cloughie - Wednesday, Mar 02, 2005 at 19:03
Thanks Oskar, Will email you 2/3.
FollowupID: 358954
Reply By: silveroak - Friday, Apr 01, 2005 at 07:04
First thing to do is check your thermostate make sure its a " High Flow " 77 deg can be a bit hard to get hold of but but will solve any overheating problems as long as everthing else is o.k.
AnswerID: 104619
