UHF - Fold Down Base
Submitted: Sunday, Feb 27, 2005 at 19:43
Member - Banjo (SA)
I've just installed an Icom IC 400 Pro UHF in the chariot. Having decided to opt for the formula ... [ performance with some inconvenience ], I've chosen to mount the antenna in the recommended centre-roof position. Its a ground plane independent 2/6 db set up - with wire screw ons: The snag is that its just too high for the shed - I need a fold down base that can still accomodate the fixed/in-line coax arrangement. Would appreciate any
feedback re hardware available - otherwise I'll make one with some stainless sheet etc.Brad has seen one in a mag somewhere - maybe others have too. Onyezorl.
Reply By: Member - Phil G (SA) - Sunday, Feb 27, 2005 at 20:02
Roof mount is always a good choice for UHF.
I have the same problem as you. I use a ground independant base which is gutter mounted. 95% of the time, all I use is a 6 inch high rubber stubbie aerial on a swing down bracket. Remainder of time I'll put the 6db up there. But being ground plane independant, side to side positioning is not critical (height always is).
Great system as you always get good transmission from the aerial being high up; The stubbie aerials actually work better in sandhills and mountains; and the stubbie aerial is indestructable and not likely to be stolen.
All the its are available at Electric Bug on Torrens road. They will gve you the same blurb :-)))
100392
Reply By: Nick R - Sunday, Feb 27, 2005 at 21:30
Banjo,
At the Surf Lifesaving Club where I am a member we have a big 5.7m inflatable boat with uhf and 27 meg, both have hinged aerials so we can back it into the shed, therefore I would try someone who does marine radios, the hinges are plastic and have lasted for years in a marine environment. Otherwise try the stubbie while you are close to
home and screw on the longer one where height is less of a problem, where we all like to be.
Regards,
NickR
100411
Reply By: Member - Captain (WA) - Monday, Feb 28, 2005 at 12:07
Hi Banjo,
I use a bullbar mounted 2.2m ground plane independant 7.0 dBa UHF antenae and it works extremely
well. I have been able to converse with others while vehicles with me could not even hear the other side of the conversation.
The 2.2m bullbar mount is, IMHO, much more convienient than a roof mount and at 2.2m tall, is overall much higher than any centre mounted aerial I have seen used. It also doubles as a flag holder for
sand dune driving. But it does get a beating on overgrown tracks.
However its a real PITA as I cannot get in in my garage, so for day to day use I have a ~800mm 4.5dBa that also happens to be exactly the same height as my roofline, great for pre-warning about low undercover garages.
Captain
100473
Reply By: Eric Experience. - Monday, Feb 28, 2005 at 22:32
Banjo.
You have made the correct choice to mount on the roof, the signal to noise ratio is much better, if you want to make an electric folding base you can use the actuator from the
seat back of an electricaly adjusted
seat, they are very strong and reliable, you will have to make a waterproof boot to protect it and if you want to make a swish job of it you can set up a couple of micro switches to make it stop and park in the desired spot. Eric.
100602
Follow Up By: Member - Banjo (SA) - Tuesday, Mar 01, 2005 at 08:55
That sounds interesting Eric - I'm happy to do it manually for the present though - I get too little exercise as it is. Whatever - I can get the electric gizmo you speak of for nix so won't rule it out.
358777
