cruiser breaks - the followup
Submitted: Friday, Feb 11, 2005 at 18:45
Member - Davoe (WA)
got the work ute back. It actually had cracked one of the 2 remaining axle studs so it must have been close to going.
From asking around it seems the causes of the studs breaking may be the locating dowells flogging out their holes and allowing play or the studs becoming loose. Other causes can include bent axles (my experience) or someone suggested bearings. Another cause I have heard of is puttind 6.2l v8s in
Reply By: Member - Phil G (SA) - Saturday, Feb 12, 2005 at 17:39
Davoe,
Sorry I missed the original thread. Most of the 6 stud Cruisers have had broken studs. I believed it to be due to lack of "anti sieze" compound on the stud threads, overtightening and jumping on the wrench etc. A smear of grease on the stud threads will do the job as
well. Then you can tighten them up to the correct torque (about 115Nm I think).
Interesting with the 5 stud Cruisers, I haven't heard of studs breaking, but its still early days. The 5 stud Cruisers have 14mm studs instead of the 12mm so maybe thats the difference. But they need to be tightened to about 150Nm.
98022
Follow Up By: Member - Davoe (WA) - Sunday, Feb 13, 2005 at 00:28
I think you are refering to wheel studs. The original post was about axle studs. i have never actually seen wheel studs break except for on a ute that had the studs about to fall off from being to loose. When tightening them I do use my leg but only to the pressure i would be able to by hand (buggered if I know whan nm that is)
356613
