GPS- Great desert Tracks cd
Submitted: Thursday, Feb 10, 2005 at 17:00
ThreadID: 20304 Views:2004 Replies:5 FollowUps:7
Could any users of Great Desert tracks gps CD tell me if it includes detailed maps of the gary junction rd and gary hwy between WA and NT and other roads /tracks linkiing to it.
I am Currently using Discover Aus Streets and tracks which does not appear to have these roads on it.
If you have both -what are the advantages of The Great desert Tracks cd as it is a bit pricey
Reply By: signman - Thursday, Feb 10, 2005 at 17:09
Yea mate
There good info on the SW & NW Great Desert (CD) maps.
Lots of GPS coordinates and info near Gary Junction, Jenkins Track and across to the CSR.
AnswerID: 97677
Reply By: Casnat - Thursday, Feb 10, 2005 at 17:58
If someone tells me how to attach a PDF file to a message I will post a sample of what the map covers in the region for you. Alternatively, if you post your email address I will email it to you
Trevor
AnswerID: 97687
Follow Up By: Ruffstuff - Thursday, Feb 10, 2005 at 18:14
Hi Trevor,
my email is mfanetti at iprimus dot com dot au
FollowupID: 356255
Follow Up By: Casnat - Thursday, Feb 10, 2005 at 18:21
email sent. let me know if you didn't get it ok.
I guess it would be useful to know how to post hyperlinks anyway if there are any guru's about
FollowupID: 356257
Reply By: ExplorOz Team - David - Thursday, Feb 10, 2005 at 18:47
RuffStuff,
I suspect that you are talking about the GDT Magellan CD and not the GDT maps from HEMA. These are two products the Magellan CD version of this is for loading the tracks onto the Magellan GPS unit or via moving map using the Magellan inferface (this products costs around $250) the other version being the GDT maps CD (costs $79) is for using with products like OziExplorer linked to your GPS and the map details cannot be uploaded to the GPS receiver.
These are two different versions of the product and perform slightly different functions however they are both build on the same map data.
I run and have copies of all these products and just about every other digital map product. If you want more info on this please call me direct on 08 9403 3737 or email me at david@exploroz.com.
Currently Mapping in the Field Across Australia Fulltime in 2024 - 2025
AnswerID: 97698
Reply By: The Explorer - Friday, Feb 11, 2005 at 00:18
Ruffstuff - Gary Junction Road and others are on the DiscoverAus CD (DAST) - you just have to zoom in past ~50,000 scale - minor tracks do not show on the screen unless you zoom in at this level - a bit of a bugger if you dont know excactly where to look as it is very easy to zoom in on barren desert country and then get peeved off panning across 500km of map at 25km at a time. You can modify a file in the program to make all tracks show at all zoom levels. (slows the computer down a bit I must say)
Another issue - Garry Juction Rd is called Kiwirrkurra Road on the DAST.
The Great Desert Tracks CD (GDT) actually has less tracks than the DiscoverAus CD...so dont buy it expecting more info. The track information for SOME tracks on GDT may however be more up todate (ie accurate) which I think is their main selling point. That is to say the extra tracks shown on DAST may no longer exist/overgrown or be position incorrectly + a few newer roads included on GDT.
AnswerID: 97786
Follow Up By: Ruffstuff - Friday, Feb 11, 2005 at 18:20
Hi Greg
can you advise how you make the track show at all zoom levels, i might give it a try.
FollowupID: 356438
Follow Up By: The Explorer - Friday, Feb 11, 2005 at 20:07
Ok navigate :) to the
Magellan\Australian's Desert\Map\Desert_Tracks directory
find map.ini file and make a backup copy (note there are other map.ini files in other directorys - make sure you find the right one)
Open map.ini with notepad or some other text editor - find the [ACLV_INFO] section shown below. The number after the = sign determines at what zoom level that feature will be displayed - if you put 0 after the = then that feature will always be dispalyed...here is my modified file with all types of roads always shown.
[ACLV_INFO]
DA_Highways=0 1 10001.000000 0
DA_Major_Roads=0 1 10001.000000 0
DA_Major_Unseal=0 1 10001.000000 0
DA_Streets=0 1 10001.000000 0
DA_Min_Unseal=0 1 10001.000000 0
DA_Trails_4WD=0 1 10001.000000 0
DA_Railroads=1 1 10001.000000 0
DA_Hydro_Polygons=1 1 10001.000000 0
DA_Hydro_Lines=1 1 10001.000000 0
DA_Border=1 1 10001.000000 0
Save the file and away you go
Have fun
FollowupID: 356462
Follow Up By: The Explorer - Friday, Feb 11, 2005 at 20:15
Wooops - sorry - just realised you have DAST and not GDT ....OK same principle different directory. With DAST the different states must be modfied individually ....for WA go to
DiscoverAus\Map\Steet_WA and modify the [ACLV_INFO] section in map.ini file
e.g. change this
[ACLV_INFO]
WA_Highways=1 1 1001.000000 0
WA_Major_Roads=1 1 1001.000000 0
WA_Streets=1 1 501.000000 0
WA_Trails_4WD=1 1 501.000000 0
WA_Railroads=1 1 1001.000000 0
WA_Hydro_Polygons=1 1 1001.000000 0
WA_Hydro_Lines=1 1 1001.000000 0
WA_Parks=1 1 1001.000000 0
to this
[ACLV_INFO]
WA_Highways=0 1 1001.000000 0
WA_Major_Roads=0 1 1001.000000 0
WA_Streets=0 1 501.000000 0
WA_Trails_4WD=0 1 501.000000 0
Keep in mind may take a while to draw as all the streets in cities will be drawn - maybe just try the WA_Trails_4WD first.
Do the same to the other state files to get same effect,
FollowupID: 356467
Follow Up By: The Explorer - Saturday, Feb 12, 2005 at 10:40
Hello again - to get all "outback" tracks to show you must have the Steets and Trails section in [ACLV_INFO] set to 0 ...ie for some reason some of the tracks in the desert are classified as streets!!.
FollowupID: 356551
Reply By: Bob of KAOS - Friday, Feb 11, 2005 at 14:48
I have the OziExplorer track files for the Gary Junction Rd between Kintore and the CSR if they are of any use to you. I can email them if needed.
AnswerID: 97861
Follow Up By: Ruffstuff - Friday, Feb 11, 2005 at 18:23
Hi Bob,
Im just starting to have a play with OziExplorer as a trial at this stage, if you are able to sed me the trackfiles to my e-mail above it would be great.
FollowupID: 356440
