Extended rotor
Submitted: Wednesday, Feb 02, 2005 at 16:33
Hano
Hi, where do I get an extended rotor in
Perth? Is it a Repco question or an ARB or other specialist store? Thanks for your help guys, i will report back when I make the switch.
Reply By: Truckster (Vic) - Wednesday, Feb 02, 2005 at 16:36
To suit?
96265
Reply By: Hano - Wednesday, Feb 02, 2005 at 16:42
Sorry, comes from earlier thread, I was having touble with my GQ missing, a couple of lads reckon the condensor and a couple an extended rotor. So its for a 89 GQ, petrol, points.
Hano.
96266
Follow Up By: G.T. - Monday, Feb 07, 2005 at 13:14
Check that the condensor is scewed down tight to the distributor base plate. If it is loose it will not be earthing properly and may be the cause of the miss that you are experiencing. Regards G.T.
355711
Follow Up By: Hano - Monday, Feb 07, 2005 at 14:07
Much appreciated GT. I havent had any luck sourcing a rotor in WA, so will
check the condensor when I get 5 minutes to myself :-)
Hano.
355720
Reply By: GOB & denny vic member - Wednesday, Feb 02, 2005 at 17:30
hano ring lpg 1 gas conversions in
lilydale melb credit card no and they will post to you
steve
look up phone no yellow pages
96277
Follow Up By: Hano - Wednesday, Feb 02, 2005 at 17:41
GOB and co,
Getting used to using this system, do I post a reply or a follow up? see below anyway, cheers Hano.
355049
Follow Up By: Member - Davoe (WA) - Wednesday, Feb 02, 2005 at 18:14
send a follow up that way they will get an email as
well and you dont have to rely on hoping they
check the thread again
355054
Follow Up By: Hano - Wednesday, Feb 02, 2005 at 18:16
Thanks Davoe.
355055
Follow Up By: Member - Davoe (WA) - Wednesday, Feb 02, 2005 at 18:16
see I got that!!
355056
Follow Up By: Hano - Wednesday, Feb 02, 2005 at 18:18
Its easy when you no how!! I got it too!!!
355057
Reply By: Hano - Wednesday, Feb 02, 2005 at 17:38
GOB,
This will sound stupid but what the hell is an extended rotor? will it fit in my dizzy? And why lpg1, the rig is petrol only, is the extended rotor related to converted vehicles, sorry for ignorance. The rotor does have a slidey (technical I know) bit on it, should i drop some lube on it, and if so what do you use in the dizzy for lube, graphite?
Hano.
96278
Reply By: GOB & denny vic member - Wednesday, Feb 02, 2005 at 21:52
goodday hano
the rotor is extended about half a bees thingy but it cuts down the air gap the spark has to jump across
when i had my gq it didnt matter gas or petrol mongrel kept missing finally somebody told me about this rotor put 1 in it never missed a beat until i traded it on the gu
lpg1 because i know they have them or another place in blackburn in melb but cant remember the name and they are a bit dearer
i replaced the condensor a couple of times had it tuned twice and changed plugs 3 times in 1 trip and it still backfired and missed all the way from the alice to melb
steve
96337
Follow Up By: Hano - Thursday, Feb 03, 2005 at 12:10
Thanks Steve, sounds like the go.
Hano.
355151
Reply By: Truckster (Vic) - Wednesday, Feb 02, 2005 at 23:29
Sandy Bowman Aus4wd in Bayswater Victoria sells them.
96365
Reply By: Member - Bradley- Wednesday, Feb 02, 2005 at 23:43
depending on the make, some stock rotors have a screw holding the plate on, and you can elongate the hole slightly to reduce
the gap, ideally the spark plug gap should be the biggest gap in the whole circuit.
96369
Follow Up By: Hano - Thursday, Feb 03, 2005 at 12:20
Hi Bradley,
Mine has a slide that must rely on centrifical force to push it out, but its as stiff as a honeymooners, do you know what sort of lube if any you can use in this situation (and I mean in the distributor).
cheers,
Hano.
355154
Reply By: stephenjNQ - Thursday, Feb 03, 2005 at 20:48
hano , the slide is supposed to slide out so as not to over rev the motor.( looses contact no spark) Performance ignition service @ nunawawading vic sells the rotor , and can be contacted on 0398723644 regards stephenjNQ.
96520
Follow Up By: Hano - Friday, Feb 04, 2005 at 11:22
Hmm I thought it was going the wrong way!! Thanks mate, am looking in WA first then will go to one of the suggested sources out of the state.
Hano.
355310
