Wednesday, Jan 26, 2005 at 02:30
Hi Andrew,
The logic of this test is not clear to me.
Let's assume that to be viewed from 45deg, a trailing driver is in the LH lane and you in the RH lane.
* If you apply the brakes, then both brake lights and hi-brake light illuminate, so should be seen OK.
* If you wish to turn left, then also should be no problem seeing the LH indicator.
* If you wish to turn right, then perhaps cannot be seen but then the person behind in LH lane so no problem. If the person in same lane, then surely they'd see the RH indicator.
I am curious as to the logic that makes the standard lights not safe in
Australia, yet OK everywhere else. And I am also assuming the rule makers forgot that people tow trailers. I know that trailers have lights, however it seems stupid to me that a simple 6x4 box trailer will obscure the lights of a Patrol.
Sorry Andrew I don't mean to be directing this at you. I own a Patrol and just think this a stupid ADR. Maybe someone will get to the bottom of the ADR and have a valid logic to present.
Regards,
Hugh
353795
