Wednesday, Jan 19, 2005 at 23:21
Okay, bit more time on the net and jogged my memory.
From memory (it was back in July and I've consumed a few scotch's since then) the exact equivalent of what Leslies recommended was the C-00-EP grease mentioned below and I think in the Castrol it may have been an EP-000 but I'm really stretching the memory there.
In the absence of that being available in Shepparton at the time and with every other equivalent exhausted and the need to put the bullbar back on the next day, I think I was able to get and used the C-0-EP. I'll double
check in a few weeks when I get
home.
Anyway this stuff is thin - like something between honey and thickened cream thin. The guys at Willow Batteries in Shep buy it in 20 litre drums (minimum pack size I think) and they will sell smaller quantities if you bring the container.
The Castrol Product Leslie's use is either an EP-00 or EP-000 and it can be bought in about a 2.5kg tub which is more than enough.
Often the problem is either the grease used originally has become water affected and deteriorated, or the last rebuilder used bearing grease. Either way the symptom is difficult to impossible freespool. This grease cured my problem and what before required significant arm & leg work now can be spooled off with one hand.
Info from Valvoline site pasted below:
PASTE
Valvoline C-O-EP & C-OO-EP Grease
These are lithium based semi-fluid greases available in NLGI 0 and NLGI 00 grades. They contain extreme pressure additives to withstand shock loads. Both greases have excellent mechanical stability and a high resistance to separation. The pump-ability of these products is excellent and they are suitable for use in the presence of moisture. They find service in the mining industry and have been specifically developed for use in automatic and manually operated greasing units when a self-levelling grease is specified. They can be used in enclosed gearbox applications where a semi-fluid grease is required and to overcome leakage in certain applications. Recommended for use in automotive steering mechanisms specifying a self-levelling grease.
Advantages:
* Can be used in enclosed gearboxes.
* Can be used in damp areas.
* Has good pump-ability.
* High resistance to separation.
Valvoline C-O-EP & C-OO-EP Lithium Grease
END PASTE
My memory is improving.. be back in a tick going to fridge for another S & C. Tchhhh. Okay let's continue...
I might also add that along with the advice Leslies gave on putting the brake back together they also tipped me off that the brush housing relies on pressure from the end cap to earth to the body of the motor housing. Corrosion here is the root of most electrical failures of these
winches.
As per some of the older bosch starter motors the solution here is to drill and tap the housing at a contact point further around the ring (you'll see what I mean when you open one up) and bolt the brush holder to the body of the motor. This requires carefull drilling and tapping for around about a 4mm screw to a thread depth of about 10mm into the housing. Once you have done this all the two bolts holding the end cap on do is just that, and to hold the motor onto the winch drum end from memory. I'd have to have another look.
At the point where you are putting the motor back on the winch have a look around the point where the motor housing mates up to the winch. You will see two short slots there. These were apparently originally intended to allow water to drain out of the motor should it be drowned (like I did) if it was mounted with the mounting flats mounted onto a horizontal surface like the bar out the front of a Jeep Wrangler or a 40 series Landcruiser. In this fashion the drum would have been uppermost. Where we mostly mount them in Australia is behind a bar with the drum pointing toward the rear of the vehicle. This means those drain slots are out of kilter by 90° from where they were intended allowing the motor to hold water.
Mine had obviously been quite wet from the time I drowned it until I stripped the winch down 3-4 weeks later. I'd hate to have left it longer.
Leslie's recommended sealing those slots with silicone. And as one last measure of water resistance for the xd9000 there were slots on the drum housing which were obviously meant for o-rings which are not put in in the factory. Leslies told me the sizes but again they'll be on the sheet on the pinboard in The Shed about 450km away and I'll get them when I get back.
I suppose by giving me the info they are doing themselves out of a job, but it sounds like they get more than they want at times anyway, and they also offered that if I got it to bits and couldn't put it back together they would accept the box of parts for a fee :o) and put it back together better than when it left the factory with the aforementioned mods done.
I guess this isn't a job for the
home handyman. I have a trade background and don't feel shy about rebuilding a starter motor or tackling the gearbox. If you do this job isn't for you. Especially the drilling and tapping the housing. But if you do it you properly you will end up with a more reliable winch.
If you don't put the brake mechanism back together properly the brake which you rely on to hold the cable where you stopped the winch and ultimately you from rolling back down the
hill to the end of the winch cable (not good eh?) may not function as intended. You don't want to find out the first time you use it half way up Ball Breaker Spur Tk with Mrs Ball Breaker screaming back down the
hill in the passenger
seat.... though potentially you could end up with an openning for a new truck and a new Mrs. Ball Breaker!
Hope this helps Poppy. PM me when you have your
membership or email davejones at iprimus dot com dot au (make the obvious substitutions.)
Dave on holidays :o)
94008
Follow Up By: Poppy - Thursday, Jan 20, 2005 at 21:45
G'Day Dave on holidays
Boy what a resonse, I guess while you're on hols you can find a bit more time to put it all together.
Mate I rang Leslies this morning and spoke to
Malcolm and he seems to think that water has ingressed the drum and seized the brake as this is by far the most common cause of freespool failure.
He explained how to go about dismantling the winch into 3 separate sections and what to look for, so I will hopefully find some time this weekend to tackle it.
He also said if I got into trouble he would fax me the info I need or failing all else if I ship it down to him he will sort it out
Dave thanks heaps for your input, I really appreciate the effort you have gone too specially while on holidays.
My turn in May... off to
Mapoon for our annual fishing trip
Cheers.....Poppy
353156
