adjustable castor bushes 100 series
Submitted: Tuesday, Jan 04, 2005 at 14:25
ThreadID: 19062 Views:1553 Replies:4 FollowUps:2
Hi all does anyone know if you can get adjustable castor bushes for the 100 series and if you can who makes them. thanks.
Reply By: Truckster (Vic) - Tuesday, Jan 04, 2005 at 14:38
Have you tried ARB?
AnswerID: 91280
Reply By: Member - Roachie (SA) - Tuesday, Jan 04, 2005 at 16:21
I've got a feeling I read somewhere that 80s and 100s have to have something welded to their axle tubes to do the same thing that off-set bushes do on patrols.
Opposite Lock or one of the steering/alignment places would know for sure.
AnswerID: 91294
Reply By: thomo - Tuesday, Jan 04, 2005 at 17:02
No i havent tried arb yet, i can get bushes were the bolt hole is offset but once its in you cant adjust it i thought someone on here might have had the same problem.
AnswerID: 91298
Follow Up By: Truckster (Vic) - Wednesday, Jan 05, 2005 at 09:33
Thats how they are. Once in they are in.
You can go for caster plates, which you can have different holes in to allow movement...
FollowupID: 349938
Follow Up By: thomo - Wednesday, Jan 05, 2005 at 09:48
Do you know who makes the plates.
FollowupID: 349943
Reply By: udm - Saturday, Jan 22, 2005 at 23:57
Go for ARB´s "OME" castor bushes at about $130 or $280 fitted. I think you can choose from 2 or 3 degrees.
PS. Don´t try to rebush the rest of the car with OME, the bush compounds are tooooooo soft. Had to get rid of em and use genuine.
AnswerID: 94482
