How long will it take?
Submitted: Tuesday, Sep 03, 2002 at 00:00
ThreadID: 1903 Views:2287 Replies:3 FollowUps:1
Can anyone out there give me an idea of how long I should allow to travel from Adelaide to Perth to Darwin (along the coast) and back to Adelaide throught the centre? I want to take it at a relaxed pace and have time to see anything worth seeing! I'll be starting in May 2003 and have got hold of a Landcruiser for 6 months. Would this be long enough?
Reply By: Graham - Tuesday, Sep 03, 2002 at 00:00
If leaving early May then I'd be going up thru the centre, as I'd want to be up north for the cooler months then head down the west coast August September. So maybe May around Alice area, then June Darwin, July Kimberlys/Kununurra then Broome/Karrartha for August then September down to Perth area & home. 6 months won't give you much time to hangabout, I'd like 9 to 12 months for the trip, it depends on how long you want to stop in places for..
cya
AnswerID: 6318
Reply By: Snake - Tuesday, Sep 03, 2002 at 00:00
Graham,
We as a family headed off for six months, (March-September) Mum /Dad and an 8 and 6 year old from central Vic in 1995. We should have, looking back spent the six months in W/A. The problem we found was not knowing what was ahead but just wanting to explore. Advise! Take your time and plan more than one trip.
P.S I still am but we will!
AnswerID: 6326
Reply By: Mudguts - Wednesday, Sep 04, 2002 at 00:00
G'day Mark,
I certainly follow Graham's advice and go north in May rather than west to avoid the cold.
You'll also find travelling will largely be withthe wind rather than against it and if you want to see the south west coast of WA it will be
much more pleasant whether in Sept/Oct than May June down there. Leaving early to mid May will put you ahead of "the pack" and
you should find most roads open and accommodation bookings not as busy. You will also get you into WA as the wildflowers are blooming at their best as you go south.
In six months you'll have time to see a hell of a lot without too much backtracking.
Have a look at our trip report on a similar trip in 2000 on Gerry Roffeys site http://www.geocities.com/flourpower.geo/caravan.htm
Its not meant to be the recipe for all but it might give you a hint or two
Good luck Ron
AnswerID: 6347
Follow Up By: Mudguts - Wednesday, Sep 04, 2002 at 00:00
That site address for Gerry is wrong should behttp://www.geocities.com/RainForest/3648/links.htm soory for confusion cheers Ron
FollowupID: 2810
