GU patrol Hazard light fuse
Submitted: Friday, Nov 19, 2004 at 19:26
bushfox
G'day all,
Wandering if anyone with a current model (old shape 2004 TD6) GU wagon has had problems with activating
hazard switch when towing trailer. Recently found
mine blows the 10amp fuse straight away, don't think its a prob with trailer as doesn't do it on other vehicles. Only occurs with
hazard switch, not indicators when used.
Vehicle wiring on TD6 is that which nissan fitted with genuine towbar/harness/plug etc.
Wandering if their circuitry is not up to scratch??
Anyone with similar experiences....??
bushfox
Reply By: timborees - Saturday, Nov 20, 2004 at 07:55
Hi Bushfox,
Had exactly the same problem when I towed my boat, but fine with my camper trailer.
Check the wiring on your trailer, if the main wire is too long or too thin it will blow the fuse, I shortened the main lead on the boat trailer (one of those removable boat light boards) and it worked fine. I would ask the guys replying above where the fuse is located, if I remember correctly I had a lot of trouble finding it (wasn't down where the bonnet release is....I think) I could be wrong it may be easy to find, I also had trouble finding an air-con fuse. Good Luck.
Timbo
85113
