Pajero iO or Suzuki Vitara
Submitted: Friday, Oct 01, 2004 at 11:18
Jimw83
Hi all,
What do you think is the better car.
I want a small 4wd and am looking at the above.
looking at the 4 door options.
which is best off road and on road
how easy is it to obtain parts for both.
plust the normal torrent of questions. (you all know them)
or am I looking at the wrong cars.
Change my mind.
Reply By: crowie - Friday, Oct 01, 2004 at 12:21
Jimw83
I cant really help two much. Much is based on what you intend using the vehicle for. Bush bashing, comuting, family travel etc.
Both are acceptable vehicles and the IO although it has not sold that
well is apparently a good capable vehicle. They both work
well off road and apart from the really serious stuff probably do the job. In some cases they work better than larger fourbees.
Comes down to comfort, what you can carry, how far you want to go, and intended use. There are others such As the Frontera, Renegade which should also be considered. Jusr remenber that a short wheelbase & firm
suspension does not make for comfortable long distance touring though.
Some thorough research on the net and driving each will determine your ultimatevehicle of choice. Good luck
78494
Reply By: Utemad - Friday, Oct 01, 2004 at 16:55
Since you see more Vitaras on the road than iOs I would imagine that there are more aftermarket accessories etc for the Suzuki.
78534
Reply By: cj - Friday, Oct 01, 2004 at 17:04
The later version of the iO with the 2.0 would be better than the earler 1.8. Just understand that there is basically nothing available aftermarket for them if you want to get a bit more enthusiastic. A Suzuki Vitara or Grand Vitara would allow the vehicle to grow in capabilities as there is a lot more support for them ie. lockers(front & rear), rockhoppers(manual & auto Vitara & auto GV), diff ratios,
suspension,
snorkel, bodyllift(full chassis not monocoque like the iO) etc. The iO is fine for a vehicle that will only see mild tracks. The Vitara 5dr comes as a 1.6 4cyl and 2.0 V6 and the GV comes as a 2.0 4cyl & 2.5 V6 in the 5dr. Also the Suzuki's have sold in much larger numbers so parts from wreckers are also more readily available as
well as the GV still being in production. For the money of an iO or GV you could have a really
well setup Vitara.
78536
Follow Up By: Member - Gary W (NSW) - Friday, Oct 01, 2004 at 21:11
cj,
who produces the rockhopper gears. I've made enquiries before and came up blank...
Gary
338049
Follow Up By: cj - Friday, Oct 01, 2004 at 21:19
Sam at Overkill Engineering (Hornsby) Good price fitted
Trail Tough (USA) Good intro price at the moment USD$649
Calmini (USA)
RockyRoad Outfitters (USA)
338050
Follow Up By: Member - Gary W (NSW) - Friday, Oct 01, 2004 at 21:23
Many thanks...is that only for the auto or is it the manual as
well..Grand Vitara
338051
Follow Up By: cj - Friday, Oct 01, 2004 at 21:35
They don't fit manual V6 GV's as the t-case is slightly different, they changed the length of the shaft.
338053
Reply By: Rick Blaine - Friday, Oct 01, 2004 at 18:28
I had 2 Grand Vitaras. the first was written off in an accident on the Oxley highway, wife was driving and we were sandwiched between 2 trucks but the passenger capsule staed intact and we both walked away... shaken & stirred. The second I traded on the T/D Jackeroo as I wanted to do some serious caravaning. The GV can tow 1800kg and used to pull our 15' poptop with ease. I found them incredibly capable on the rough, very comfortable to travel in and they had a high level of creature comforts. The only downside I found were genuine parts were very expensive and our local (
Canberra ) dealers were very clever at extracting every dollar they could at service time. Check out the underside... I liked the forged
suspension components and full chassis.
78545
Reply By: AK - Saturday, Oct 02, 2004 at 09:08
I had a Grand Vitara and it went very
well. I looked at the iO but it had no storage space compared to the GV and even it was marginal. The suzuki is very capable once you get rid of the original tyres. I had the v6 and was very impressed.
AK
78589
