Smoking Pajero
Submitted: Monday, Aug 05, 2002 at 00:00
ThreadID: 1656 Views:5945 Replies:7 FollowUps:2
I have a 94 NH 2.8D (no turbo). With winter and cold mornings, after start up, blows a lot of white smoke and misses badly. Only lasts for a short time then is ok. Had glow plugs checked and told they too were ok. New problem. Driving along with engine nice and warm when the vehicle feels to be under load (towing a trailer), motor misses a beat and a burst of white smoke fom exhaust, then back to normal. Any thoughts.
Reply By: CHRIS - Tuesday, Aug 06, 2002 at 00:00
I wouldn't mind betting you have a blown head gasket-cracked head or a warped head that is allowing water into the cylinder.Are you losing any water.
AnswerID: 5432
Follow Up By: Ross - Tuesday, Aug 06, 2002 at 00:00
Problem is that nothing else is out of place and not using water. oil is clean ands no visable problems in the engine room.
FollowupID: 2350
Reply By: johnf - Tuesday, Aug 06, 2002 at 00:00
May be time to get a Prado - never missed a beat.
AnswerID: 5433
Haven't won the Paris to Dakar rally either!!!
FollowupID: 2351
Reply By: scotto - Tuesday, Aug 06, 2002 at 00:00
Sounds like you have more than 1 problem. Your glow plugs might be OK but what about the timer? Could be not suppling correct volts or for right amount of time. Power loss could be anything, ring SMS on 02 9714 2500 as they have a diagnostic engineer who can advise you for free.
AnswerID: 5448
Reply By: kezza - Wednesday, Aug 07, 2002 at 00:00
White smoke is your clue - seems to be a fuel delivery problem, running lean for some reason momentarilycheck filters especially the tiny banjo filter in fuel pump also injectors "may" need a service. - not much can go wrong really apart from this. Also timing problem may cause this but too erratic (still stranger things............)
good luck
Kezzza
AnswerID: 5460
Reply By: ray91 - Wednesday, Aug 07, 2002 at 00:00
hi Ross I to would like to know why the white smoke.My nissan patrol 2.8 turbo diesel has started to do exactly the same thing even missing a beat when warm.I have tried the local diesel garage they say the injectors need servicing but they always say that whatever is wrong
AnswerID: 5482
Reply By: steve - Tuesday, Aug 20, 2002 at 00:00
I own a MQ diesel and is doing the same thing lucky for me i work with diesel machanics they told me that the injectors aren't operating properly in the cold mornings (it doesn't happen in the summer) there spray patern is uneven and the droplets are to big, and with a cold diesel engine they don't burn properly wich causes the white smoke and running ruff until it all clears and the injectors work better. the glow plugs are another thing that will cause this and more than likely if the smoke clears up and goes black when under load or changing through the gears. So don't forget that white smoke is unburn diesel fuel and blue smoke is oil burning i hope all this makes sense and helps
also there is a lot more to be told about this problem what i have said is rather quick and simple.
AnswerID: 5858
Reply By: dennis - Tuesday, Aug 20, 2002 at 00:00
you dont mention kms or service history. any inspection should include things such compression testing & cylinder leakage. white smoke is associated with incomplete fuel combustion and can be caused by poor compressiion , incorrect fuel timing or maybe a primary fuel pressure problem in the injection pump. ps i dont think any STANDARD pajero ever did very well in the P-D
AnswerID: 5859
