Fridge dividers
Submitted: Sunday, Jul 25, 2004 at 09:51
Phil P
Hi all,
I know I've read it somewhere, I've searched the
forum but with no success !
Someone mentioned a product you could by from Big W or the like that was low cost and suitable for use as internal fridge dividers ?
Jog any memories ?
Phil P
Reply By: Member - Rick (S.A.) - Sunday, Jul 25, 2004 at 10:20
How about a sheet of very thin ply, cut to your necessary dimensions.
I use one to go on top of the frozen/cold goods at the botom of the fridge. This way the lettuce & other sensitive items sitting at the top of the fridge are not ruined.
69494
Reply By: Jimbo - Sunday, Jul 25, 2004 at 10:37
From memory these were some type of plastic container that you fasten to your fridge basket with cable ties, forming little compartments in the top of the fridge. I wrote it down at the time, planning to get some, but lost the note.
If anyone can help, I'm interested too.
Jim.
69499
Reply By: Tripp'n Around - Sunday, Jul 25, 2004 at 11:55
Hi Phil
Maybe perspex might be the go?
For our needs:-
We used 5mm perspex cut in half and hinged so we could get to either side of the frozen stuff on the bottom without emptying the whole contents of our Trailblaza.
It worked a treat until we hit the corrugations on the southern bypass road up the Cape on the way
home.
The perspex broke so we are going to try the same thing but with ply or similar next time.
Cya
Tripp'n
69507
Reply By: Member-Steve (Pilbara) - Sunday, Jul 25, 2004 at 15:58
2 layers of Marine grade carpet glued together will do the trick. It doesn't rot and is easy to wash and dry when you get
home.
Steve
69532
Reply By: dingdong - Sunday, Jul 25, 2004 at 18:47
Hi Phil,
THey are called handy basket small , brand is LTW item No is 1003 . They are fantastic we only needed one in 39L engel tied in with some plastic covered ties .Hope this helps .
Cheers dingdong
69560
Follow Up By: Phil P - Sunday, Jul 25, 2004 at 21:05
Hi Dingdong,
Are these from Big W ?
Phil P
329873
Reply By: dingdong - Monday, Jul 26, 2004 at 09:39
Hi Phill,
Yeh from big W I think $3-60 each we bought 2 but only ended up using 1 kids got them for us in
perth as we couldn't get any in
Geraldton although there were some items in town by same manufacturer but not suitable .
Cheers dingdong .
69683
