Tuesday, Mar 04, 2025 at 09:34
"AmpHrs" is certainly in common usage in the RV industry Macca, but no where else, and it is generally assumed to be at 12V. Problem is, things are changing like never before.
If you buy a battery for your house solar system, it is rated at kWh (along with the solar) and many of us are going Lithium in our RVs with a nominal 12.8V (or maybe higher) instead of 12V.
So the value of an "Ahr" can not be safely assumed any more.
What prompted my post however was that some of the values looked like they might have been Amps draw rather than Ahrs consumption. For similar reasons to above, Watts takes away any possible confusion and equally applies to the 240V fridges (and other appliances) that many are running via
inverters in their RVs. Those
inverters quote power capability in Watts, not Amps.
The OP has produced a great body of work (and he did ask for
feedback). My post was intended to be constructive. :)
ps... as I said in my post, getting reliable energy consumption information will be problematic. The power (Amps - watts) number is likely to be more accurate, but it is the energy (Ahrs - Watt hours) number that is harder to establish because it can be so variable. It is also the only number that is really important which makes it quite a challenge.
928579
