Monday, Mar 03, 2025 at 07:14
Hi Bob C17,
This is a difficult question to definitively answer, as we do not know the mechanical condition of your vehicle and camper, (no offence intended), nor at this stage the condition of the road.
Having said that, the GCR is a
well used outback “highway”, its condition can vary from week to week, and sometimes day to day. It has been a while since I travelled the GCR, but the area around Docker River can be very sandy. I also found the section around Warakurna (
Giles Weather station), was very corrugated. This of course is dependent on when it was last graded, the weather, and how much traffic it has seen. To find out about the road conditions, you are best to contact the Warakurna community closer to your travel time. Of course, you will need two travel permits, one for the N.T. Section, and one for the W.A. section. Both are obtainable on line. These permits also allow you to
camp within a few metres of the road.
As for your vehicle, and camper, as always, you will need to lower your tyre pressures and drive at a speed that is not only suitable for the road conditions, but also suitable for the lower tyre pressures. Whilst it is a
well travelled road, it is also a good idea to have a reliable means of communication.
UHF Radio is good for “line of sight” comms, but a Satellite Phone and an EPIRB/PLB is also a good idea. Mobile Phone coverage is sparse in the outback, and you are unlikely to have signal unless you are close to one of the communities. Telstra or Boost Mobile have the widest coverage in Australia.
Good luck with your trip, there is quite a bit to see on the GCR.
647502
