End my Frustration - What are the grey lines and how Do I remove?
Submitted: Saturday, Dec 28, 2024 at 23:52
ThreadID: 149361 Views:656 Replies:2 FollowUps:3
Dunno what I have turned on but the grey Stright lines are annoying me ??
I am sure it is something simple :-)
Mature Couple - Still working!! waiting to make the BIG STEP to go travel this big country of ours.
Reply By: Member - wicket - Sunday, Dec 29, 2024 at 07:01
Tap one of the lines and the dynamic legend appers informing you that those grey lines are fences
AnswerID: 647099
Follow Up By: Member - Mark B68 - Sunday, Dec 29, 2024 at 07:38
Can they be removed as they are on ALL Trips/Treks ?
FollowupID: 927886
Reply By: ExplorOz - David & Michelle - Sunday, Dec 29, 2024 at 10:42
Not sure which grey lines you mean, but if you mean the thicker dashed line, then these show point to point heading to each Place in your Trek. They serve a navigational purpose. If you don't know how to use them, then ignore. Like most things with the Traveller app, it will all become obvious once you commence real use.
AnswerID: 647101
Follow Up By: Member - Mark B68 - Sunday, Dec 29, 2024 at 11:48
All good... they are in all treks, trips, routes...
Going through all the tutorials again.... :-)
'Using Treks' is a bit of a head spinner ....
FollowupID: 927888
Follow Up By: ExplorOz - David & Michelle - Sunday, Dec 29, 2024 at 14:59
Probably what Wicket said then - fences. Nothing to with Treks, just topographic info on map. Turn on the Dynamic Legend using map layers and anything you dont understand on map just tap then all will then be revealed eg…
FollowupID: 927889
