Headunit suggestions for S1 Patrol
Submitted: Sunday, Dec 22, 2024 at 18:35
ThreadID: 149329
FollowUps:4
Brian-Wood
Hi there
I’m wanting to upgrade the double DIN headunit so I can do the following:
1. Have a camera input
2. Run Apple CarPlay
3. Separate to CarPlay, run
ExplorOz Traveller.
4. Output quality audio
Does such a system exist?
Reply By: IvanTheTerrible - Sunday, Dec 22, 2024 at 19:57
Yes they exist. Any major brand double din headunit with the appropriate specs will fit with a fitting kit. We usually
check out whats on special that fits our customers needs
647025
Follow Up By: Brian-Wood - Sunday, Dec 22, 2024 at 21:30
Thanks. I’m not sure they can all run
ExplorOz Traveller tho?
927816
Follow Up By: IvanTheTerrible - Monday, Dec 23, 2024 at 19:48
If you get mirroring you can. Mirrorlink is limited though but does share your phone screen to the headunit
927832
Reply By: ExplorOz - David & Michelle - Tuesday, Dec 24, 2024 at 09:43
If you don't buy yourself a headunit that built on a full Android operating system you'll still have to buy an Android AI Box Adapter so that you can. This is purely for point 3 - to run
ExplorOz Traveller.
If you read the
ExplorOz Traveller webpage we have a section on headunits that clarifies the common brands that our app users are buying.
Also suggest you read the section on using Apple CarPlay in conjunction with this info to confirm if you need point 2, or skip out that function.
Michelle
647049
Reply By: Brian-Wood - Tuesday, Dec 24, 2024 at 10:47
I’ve now decided to run with a standard head unit and a separate iPad mini for the maps. This will give me far more versatility
647053
Reply By: ExplorOz - David & Michelle - Tuesday, Dec 24, 2024 at 11:56
This shows the Traveller on different types of headunits.
First 2 photos shows an aftermarket Android head unit (EC Offroad) fitted in a 200 series Landcruiser. Traveller installed direct via Google Playstore download.
Traveller app on Android headunit
Full Android headunit
The third photo shows the factory fitted CarPlay headunit in a 2023 Range Rover - there is a CarLinkKit TBox Android AI box adapter plugged into usb port of headunit.
Factory fitted headunit (Carplay)
647056
Follow Up By: Member - David M (SA) - Tuesday, Dec 24, 2024 at 17:58
Michelle, I see in your posts you say that your " Currently Mapping in the field"
You sure your not just having a really really good time.
Dave in
Adelaide mowing the lawn.
Merry Christmas.
927844
Follow Up By: ExplorOz - David & Michelle - Friday, Dec 27, 2024 at 10:36
Hi David, yes same thing
927876
Reply By: Brian-Wood - Thursday, Dec 26, 2024 at 21:33
It seems the Polaris GUMaxx head unit will do the trick.
Anyone had any experience with these?
647090
