Trek download on iPhone 18.1.1
Submitted: Friday, Dec 06, 2024 at 12:49
ThreadID: 149261
FollowUps:3
mgriff81
I've imported a gpx and have it as a track log, to navigate the route select it from
Treks. I see a total of 190
treks on the server, but not able to retrieve the to phone.
The downloads for the others hang at 50%, what's the issue on that also?
Also is their a way to associate gpx files to ExploreOz in iOs, i had to delete the all gpx apps to be able select a gpx file and import a file, otherwise all were greyed out.
Mark
Reply By: ModSquad - Friday, Dec 06, 2024 at 18:08
Please be aware that for app support you should use the Help Desk.
646900
Follow Up By: mgriff81 - Saturday, Dec 07, 2024 at 01:58
Sorry, was searching for similar issues and came acrosss discussions on ios issues, will take your advice and be aware.
927650
Follow Up By:- Monday, Dec 09, 2024 at 16:47
Hi mgriff81
Please do not allow yourself to be intimidated and bullied on this
forum. And I certainly would not be apologising to the bullies.
You asked a sensible question here and someone with experience was able to chime in with an answer, so good. If not, David or Michelle are usually not far away to help out. The problem with the help desk is that other users never get to know the answer and in most cases never even know there was a problem. Always good to have this information for future reference if needed I feel.
Roy G.
927659
Follow Up By: Member - McLaren3030 - Tuesday, Dec 10, 2024 at 07:18
Roy G,
No one is “bullying” anyone, and for you to suggest that is just not accurate or acceptable. It was David and Michelle who initially requested these type of technical questions be directed to the help desk. That way, the people who designed and built the website and who are in the best position to give the correct answer, are the ones to respond. They will try and replicate the issue and work out the most appropriate response.
927660
Reply By: Bonz (Vic) - Monday, Dec 09, 2024 at 12:31
I was able to associate by emailing myself the gpx file and then click and open it in email and look for the little box with the up arrow on it and touch that and a list of programs comes up and select EO traveller (and addit if its not there in the selectionsd). Worked a treat
646926
