BUG regarding Incorrect 'travel time'
Submitted: Thursday, Dec 05, 2024 at 15:23
ThreadID: 149258 Views:475 Replies:1 FollowUps:2
Hi Folks,
I've been creating some off-road treks and sometimes need to use 'cycling' instead of 'driving' as the form of navigation.
I've found that if any section of my trek uses 'cycling' and I then select '4WD' from the 'Suitable for' dropdown menu, when recording details about the trek, it will stuff up the travel time.
The fix is to simply NOT select '4WD' from the 'Suitable for' dropdown menu.
Hopefully the screenshots explain this better.
Reply By: ExplorOz - David & Michelle - Thursday, Dec 05, 2024 at 20:38
For any calculated route segment the avg speed will be displayed in a box that you simply override before clicking accept.
AnswerID: 646893
Follow Up By: Member - JA1 - Thursday, Dec 05, 2024 at 20:52
Hi Guys,
Yes I realise this and change it to a faster pace when I choose ‘cycling’. to mimic drive pace The issue is that when a trek combines a cycling and a driving section AND you then choose “4WD” from that dropdown menu it creates the error.
I’ve tried it on several different tracks and the error always happens. It always corrects itself once I unselect 4WD from the drop down menu y
FollowupID: 927644
Follow Up By: ExplorOz - David & Michelle - Friday, Dec 06, 2024 at 08:01
That drop down setting should not do anything to the routing calculation system. It is purely for filtering and information purposes. So I am very confused why this is changing on your result.
I would be happy to continue investigating with you if you would not mind starting a new help desk (see footer link below) job and give me the trekid number of the treks that exhibits this so I can check it out and see what is happening.
David
FollowupID: 927647
