Tuesday, Oct 15, 2024 at 19:35
Some of the specs and sales blurb are scary.
90A is a huge amount of power, much more than required to compress the air. The "extra" will show as heat which is anticipated in the sales info....
................."If the unit reaches an unsafe operating temperature, a protection circuit will activate cutting off all power of the unit to prevent damage. Immediately disconnect the unit from the power source and allow it to cool if the protection circuit activates. The unit should take approximately 15 minutes to cool depending on ambient conditions."
................"+ After 5 minutes of continuous operation allow the unit to cool before restarting. Damage can
occur from continued overuse."
And this limitation....
................."Maximum Voltage: 13.8 Volt"
If you start the engine while using the compressor to run the alternator to maintain the battery capacity, the 13.8V limit at the compressor will be exceeded.
And this...
....................10.Allow the air compressor to cool completely before placing inside the carry bag. "
Which will take 15 minutes, is what they tell us.
It will be a race between overheating the compressor and flattening the battery.
I would not purchase this product.
927389
