Saturday, Oct 05, 2024 at 00:34
Allan, Like the OP I also have a PX
Ranger and a common failure these have is the EGR cooler. When it fails it is not always total and immediate, but under those circumstances it may
well work and give the owner a chance to turn off the engine before the failure causes further engine damage.
In our case the failure was quite slow. We were 3000km from
home with only one Ford Dealer about halfway. I noticed the level slightly lower than normal in the remote mounted expansion/overflow tank than so just topped it up. we continued
home and at every stop, fuel, rest or nightly, I rechecked and topped up. It amounted to about 2.5 liters for that distance. There was no visible external leak or the suggested white smoke out of the exhaust for an EGR failure condition.
At
home I booked the vehicle in as it was still under warranty, and it had to be tested overnight to detect a pressure drop. Cooler replaced.
I have no idea with the kits that measure low coolant loss as to how much has to be lost before they activate an alarm condition, but as to my slow leak you would have to negligent in not doing a
check under the bonnet at least daily for all fluid levels and it shouldn't get to the stage of the level alarm activating. Is there one of these kits that actually checks the level in such a remote tank, not in a radiator hose? I had looked up a couple a few years back but didn't see one then.
I'm now a bit paranoid and
check the coolant level more than once a day on a trip until I can hopefully get the EGR cooler permanently blocked and bypassed.
Personally, now that I've had both a rapid and a slow leak condition, I would prefer to have a system that can cover both incidences.
927245
